  • Online today: 500
  • Guests: 376
  • Total: 376
transmission leak
Started by montty, August 24, 2008, 05:51:17 PM
Like apintonut said TRANS X I have had 96% fix including power steering.   Fred   :)
montty
Where can I get a vacuum line diagram for a 80 pinto
I heard that this is typical for the C3? Is that true?
Anyhoo, my old C3 was leaking, but I'm fixing it by swapping in a turbo engine and world class T5.  :afro:
Quote from: montty on August 24, 2008, 05:51:17 PM
I have a 80 pinto wagon, with a c3 trans, leaking out of the front. any ideas?
Yes, a few, BUT it depends on your definition of 'front'.
Are you saying it is leaking TRANNY FLUID out from the bell house area?
If so, it most likely is the front pump seal, but it could be the t-converter drain, split T-converter, bad cooler line, or someting else.
The seal is easy to change, but you need to remove the tranny or the engine to do it.
I just changed the front seal on a C3, that was leaking like a faucet.
Quote from: apintonut on August 24, 2008, 05:58:06 PM
trans X works wonders
I have had GREAT success with Lucas tranny treatment, but it all depends on what is wrong as to how good a job it will do.
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
montty
