Date: 07/17/2018 09:22 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 07/08/2017 08:25 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 02/21/2022 11:11 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 11/11/2019 04:49 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
  • Online today: 288
  • Guests: 254
  • Total: 254
Tremec vs T-9
Started by Ironman, August 22, 2008, 09:23:44 PM
turbo74pinto
Quote from: Ironman on August 28, 2008, 12:20:15 AM
Thanks,..That was a nice link to visit. The Bellhousing he used is the same one I'm getting. Cosworth also  makes one,.. but they are 100 dollars more. I was a little confused because he said the bellhousing wasnt set up for the hydraulic clutch,.. I'll have to look into that,.. currently the quad rod place has 3 different bellhousings for the Duratec. maybe one is allready setup to take the hydraulic clutch.
Mick
do you already have everything for hydrolic??  why not stay with standard cable?  just curious.
bob
You might want to take a look here:
http://www.fordpinto.com/smf/index.php/topic,8574.0.html
It has some good info on gear ratios. The T-9 is a weaker trans than the T-5  / Tremec. The Merker guys eat up the T-9s pretty quick when they start making horsepower.
Ironman
Quote from: turbo74pinto on August 26, 2008, 06:52:58 AM
check this link too:
http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=3;t=025488
a guy is putting one in an svo.  he gives some info on the bell housing youll need.
bob
Mick
Ironman
turbo74pinto
bob
Ironman
Quote from: turbo74pinto on August 25, 2008, 06:25:03 AM
yeah, thats a t-5.  tremec t-5s are the same as the borg warners.  the companies merged somehow, dont ask cause i have no clue how or why, in the 90s.  i want to say tremec had something to do with all t-5 trannies from 91 up.  i could be wrong on that though.  when they came in the picture, the trannies got a little stronger.  the t-5s actually come in a ton of variaties.  you have to watch your input shaft length.  i know fox bodied 4 cyl were shorter then the 8cyl by i think 3/8 of an inch.  94-95s were longer by almost inch.  read here for more info:
http://www.allfordmustangs.com/Detailed/349.shtml
what are you looking to do with this tranny?
bob
Thanks for the info and the link. Very helpful stuff. after looking through the web page I've determined mine is a late model WC, with electronic speedo. That means I have the long input shaft and 300 ftlbs torque capability,  Duratec wont even come close to taxing this gearbox.  I am very pleased with this aquisition.
As far as what I intend to do with it,... I'm putting an 06 Duratec 2.0L from a focus into my 71 sedan. The info from the the link you gave me, will be very helpful in ordering the correct Bellhousing to make the adaption.
Much appreciated.
Mick
Ironman
turbo74pinto
bob
Ironman
Quote from: turbo74pinto on August 23, 2008, 06:08:19 PM
tremec is stronger.  but unless its the tremec t-5, they have a different bell housing bolt patern.  tremec t-5 is nothing really special, basically just a stock wc v8 tranny that will handle a little, but not much, more hp and tq.  the tremec tko's are some bad mofos.  but they are clunky and no where near as easy to shift as the standard t-5s.  try googleing g-force transmissions.  they have some great gear sets to swap into your standard t-5 housing.  i think they have kits that replace the weak forks too.
bob
Thanks for the info.
I probably sound like I havnt got a clue what I'm doing,.. that may be largely based in fact :surprised:
The wrecking yard said the T-5 came in two flavors,.. the one I have came from behind a 3.8L V-6 mustang.
That and the price would make me think I've got the lesser of the two.
I am a little confused about the "tremec" T-5 thing. Are they not the same transmission?
The trans I have has a tremec sticker on top, and the Borg Warner logo on the side right below the shifter.
I'll include a photo
Ironman
turbo74pinto
bob
Ironman
Is one better than the other?
I'm guessing niether is as strong as a T-5,.. but I wouldnt know that either,.... any imput?
Ironman
