1980 hood needed
Date: 04/23/2020 10:41 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 10/28/2018 08:45 am
Date: 10/02/2017 02:16 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 10/10/2019 09:42 pm
  • Online today: 2,457
  • Guests: 581
  • Total: 581
project beentoad
Started by apintonut, August 22, 2008, 08:24:44 PM
Cut the bottom (inside) of the cowl out of it.  When I had the one from my parted and dead 76 stang II out, it must've weighed 50 or more lbs!  There is a LOT of weight in those doors too, I am assuming you are trying to keep the doors functional, but it may be better just to weld the skins onto the outside of the rest of the body.  If you want to lighten the whole thing a bit, try swapping the full rear diff for a straight axle out of a FWD minivan.  Not sure what would fit, but could be fun to peruse the pick-a-part yards with a tape measure.  It couldn't be too hard to weld spring perches on one of them.
Good luck, and have fun!
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
apintonut
well that was the wrong pic! that is a pic of a add my dad (av8pintonut) did for pullzall! i was trying to resize it at about the same time, that i put that post
Yah Brian your image isn't loading all the way...
FrankBoss
That must be a really big slip up with a a really big drill. It even broke your jpeg!  :laugh:
apintonut
slipped up with really big drill
Ironman
Quote from: apintonut on August 25, 2008, 04:25:49 PM
door bar removal and ooops's.  they weigh 20 lb each!
So I'm looking at picture 3, and I see something that looks like a 45.cal hole.  were we having a difficult time with the door bars?  ;D
Ironman
apintonut
Quote from: dholvrsn on August 25, 2008, 05:03:52 PM
Beentoad once popped out of park and rolled into a pond. But it was okay since the water was only knee deep, knee deep, knee deep!  ;D ::) ;D ::) ;D
hmmmmmmm amphibi-pinto  :) :) maybe another project soon
apintonut
Quote from: dholvrsn on August 25, 2008, 04:53:12 PM
Beentoad, held together by rivet, rivet, rivet!  ;D ::) ;D ::) ;D
rotflmao
yah!!!!! that how i intended to add the front panels
apintonut
apintonut
any one have any ideas on this project
what can be cut
how to brace / support
moving the axle forward
should i make frame connectors
apintonut
man its raining.  i have the welder out and ready to go.  just dont like using power tools in the rain if i dont HAFT to.  so another day lost!!
Ironman
I thought it was called "Toad" because with the nose cut off the rust bubbling paint and such, it does in fact look like a "Toad".  There is something kind of rewarding about going after something with a sawsall isn't there!!
Ironman
apintonut
milti play on words.   yes towed it as in to pull but final paint will most likely be lime green pinto color. much like a frog's color and its use is to go camping in the woods. were it is not uncommon to find a toad's.  just some slite humor for my own enjoyment .  thanx for asking though. maybe some one els will see my lame sense of humor
Pinto Pro
Why do you want it to be "toad"...when it can be "towed"?? :D
apintonut
apintonut
cut cut cut.  now the floor wont support my wight. time to brace
apintonut
im thinking of cutting more than i did im wondering if i cut in front of the door support if it will stay together
apintonut
well final paint will most likely be the pinto lime green or a brown. but that is most likely more than a year away but the camo in 3-4 weeks  but im playing this by buy ear. im in cut and weld stage. i dont want to have it fold in half on the first good bump. but im also trying to cut as much off the car that i can. i also tried to drill out the door bars but they did not come out. i drilled the 4 spot welds on ether end but they dont move. i hafta get the door bars out there good for about 60lb and the window for another 40 lb. losing the weight will help with the structural  stress.
now to the point im going to cut out the tunnel and patch it but how much will this weaken the body. how much dose the tunnel & fire wall support  how can i get the door bars out.
apintonut
that would be more work when i went to Finnish it out
apintonut
this should only take 3 weeks to be able to be used but much much more time to be at the show ready stage i plan to first focus on the frame work then the inside then it is will be operable. then it will be put to the side for the 74 turbo after that is done i will go back to tackle body and paint but it will most likely get a camo temp paint
Quote from: turbopinto72 on August 22, 2008, 09:07:46 PM
So why isn't Tony here posting " Just say NO to Pinto Trailers" ?
:lol: Only if he doesn't finish it!!  :lol:
apintonut
this just had to much rust to bother with making nice see pic and there is one more spot about the same size but it is still very solid.
Oh I see, so its just the " V8 " part that offends ?
because people tend not to put V8's in Pinto Trailers
FrankBoss
apintonut
