Pinto brake booster needed
Date: 05/08/2021 09:00 am
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 06/22/2017 07:19 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
  • Online today: 295
  • Guests: 168
  • Total: 168
dashlight fuse keeps burning out?any help please!!!
Started by jeffster, August 15, 2008, 07:35:37 AM
My mistake, the shifter light does not dim, it is on the parking light circuit
lugnut
Quote from: 71pintoracer on August 15, 2008, 10:06:27 PM
I don't understand how the shift indicator light is still working, it should be on the same circuit. Did you recently change the radio to an aftermarket unit? I have fixed many where they took a test light and found that the yellow wire is hot w/ the key on so they figured the blue/red trace wire was the ground. The radio would work because it grounded through the antenna or a metal bracket and when the headlights were turned on, pow!! Blown fuse.
On my cars, the light in the shifter indicator is not connected to the instrument light dimmer.  Strangely, I only recently noticed that!
mike
just make sure the light blue/red tracer wire is not hooked to ground.
billnall
Ford Parts Man
Trace the wire from the light switch potentiometer to the back side of the cluster. I'm guessing that you have a wire pinched between two metal pieces or a bare wire rubbing against metal.
Quote from: jeffster on August 15, 2008, 01:21:31 PM
can a switch keep blowing the fuse,just for the dash lights?
Yes, the dash lights are on a different circut. If they were on the same, you would dim the headlights when you dim the gauge lights.
jeffster
i have a 1977 pinto cruising wagon.the fuse keeps burning out for the dash light as soon as i put the headlights on?the only lights inside the car that work is the shift light indicator.all of the outside lights work fine,headlights,brake lights,hi lo beam and even the dash hi lo beam indicator light works.any and all help would be great.thanks
