SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 03/15/2023 02:16 pm
Date: 07/03/2025 04:35 pm
Date: 10/31/2018 12:00 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 11/04/2018 02:34 am
Date: 01/19/2021 03:56 pm
Date: 08/20/2017 01:34 pm
Date: 10/31/2018 12:04 pm
  • Online today: 445
  • Users: 1
  • Guests: 291
  • Total: 292
  • 78txpony
where is the serial number
Started by fordpinto123, August 10, 2004, 07:21:20 PM
Axryn
  First let me point out this is not an exact science , more detailed information is available in specialty books for decoding FOMOCO engineering numbers. If you get really lucky look under the coil mounting bolt you'll find a tag with a wealth of information ( engine c.i.d - model year-change level-month and year of engine production). Unfortunately FOMOCO never actually recorded serial numbers on their engines. They did however stamp their engines with engineering numbers which can usually get you into the ballpark for year and intended model the engine was built for. The engineering number for example looks like this C5AE-6015-E ,( located at the right rear of the block ) would indicate a 1965 (A=1940's B=1950's C=1960's etc. next number indicates actual year of the decade) So we have a 1965 engine. 3rd digit is an "A" meaning it was for a Full-size Ford. 4th digit should always be an "E" for engine division. Next number is referred to as the BASIC ( 6015=block , 6090=cylinder heads many more you get the idea ) Last digit is the design level (A as designed B first change to design and so on ). This is intended to be a guide not the gospel. Engine size is usually located between the lifter galleries. Hope this helps.
fordpinto123
do u know where the serial number for a 289 or 302 is
