Date: 02/22/2017 01:58 pm
Date: 02/04/2018 08:26 am
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Date: 03/17/2019 03:57 am
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
  • Online today: 1,137
  • Guests: 687
  • Total: 687
rear window(hatchback) defroster?
Started by russosborne, August 11, 2008, 12:30:07 AM
I would assume that it is required to make use of the defrost circuit, as the ones on my Saturn Ion must both be connected for it to work. Any glass should should be able to attach another tab to the circuit and replace the wire to make it operational again.
best of luck!
I have a 79 hatchback. It has the rear defroster, but the passenger side wire is missing from the hydraulic lift support to the glass.
I was wondering if the defroster will work partially, like every other strip, or is this wire needed to make the circuit complete for the defroster to work at all? Or, is this wire even part of the circuit?
If it won't work at all as is, any thoughts on how best to fix it. I will need this to work once winter gets here in Ohio.
Thanks,
