Date: 03/23/2018 09:23 pm
Date: 03/13/2021 12:57 pm
Date: 03/25/2019 09:02 pm
Date: 12/09/2018 11:35 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Seeking parts
Date: 10/18/2020 10:35 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 210
  • Guests: 180
  • Total: 180
A 1980 that does not want to idle
Started by chunk41, August 07, 2008, 09:42:30 PM
chunk41
thanks for all your help guys....ken
lencost
Quote from: chunk41 on August 11, 2008, 09:07:50 PM
;D thank you.....the way it loos I will have to replace the wire also.............
I had to replace mine from the splice to the solenoid. Do not scrimp on the wire diameter. This wire runs from the battery side of the solenoid to the voltage regulator, and about in the middle of the wire is a splice. Off of the splice are tow more wires one goes to the ignition switch "it's yellow to" and a black one that goes to the alternator.
1975 Wagon 8" C4 2.8 V6
chunk41
lencost
Quote from: chunk41 on August 11, 2008, 08:54:53 PM
yes it does.......4 pin hookup on the bottom...............do you think could be the problem for the intermediate spark?........
Possibly.
Electronic devices are sensitive to voltage fluctuations.
chunk41
lencost
Quote from: chunk41 on August 11, 2008, 08:33:16 PM
the car was running great.......I just found a bare wire running into what I think might be the control module....it is on the drivers side fender behind the washer fluid bottle and it has a condensor connected with it....the wire runs from tha module to the starter cylnoid.it is yellow and a red and green wire (I think thats the color).tee's off of it....I was doing the old school check for spark by grounding a plug to the fender and it would spark maybe every 10 to 15 cranks..........what do you guys think/.......thanks for all the help..I would really hate to scrap this car.........ken
That might be the voltage regulator. Dose it have a stamped sheet metal cover?
chunk41
Quote from: chunk41 on August 10, 2008, 02:44:49 PM
the carb is new....
I have bought 3 rebuilt carbs for my different Pinto's in the last 2 years.... ALL!!!! of them needed to rebuilt again by a local guy here in town. 1 of them was having the same or similar issue you have described. Hard to say if you are seeing the same thing and if it's the carb but in my experience... rebuilt carbs are questionable.
I would guess most were rebuilt many years ago and have been sitting on shelves ever since...
What did it do before you did all those things?
chunk41
the carb is new....could it be something electrical like in the distrubitor?..........thanks for your help ken......
chunk41
I have a 1980 pinto that is starting to drive me nuts..these are the things I have done so far....put a new coil on....replaced the rotor.......replaced the starter cylnoid....replaced the carberator and fuel pump.....droped the fuel tank cleaned it out and blew the lines out...put a clear filter inline before the pump.........the problem is once I start it it wil idle high but once you hit the gas it will shut down ans will not star for about 10 minutes.......anyone have any Ideas............. ???........thanks ken
