Date: 10/02/2017 02:16 pm
Date: 07/08/2017 08:53 pm
Date: 08/09/2018 11:09 am
Date: 11/11/2019 03:38 pm
Date: 08/02/2019 04:18 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 04/20/2017 08:56 pm
Date: 09/03/2018 08:58 am
  • Online today: 529
  • Guests: 343
  • Total: 343
Duratec pinto conversion
Started by Ironman, August 07, 2008, 04:58:01 PM
tintmaster
Just found a motor with 17,000 miles out of a '07 Focus. Can get it with ECU and harness for $650!!! Now just need more business....
C. Eugene Brown
Wife's Rangers have 4:88s . Main reason they are so snappy !
She wrote off (she is OK) an 07. I wanted the truck back for the rad to rear diff for a beater car (Pinto) for "fun" & no worries about our gravel roads.
No luck. Insurance co. made it so I couldn't get it back.
blink77
I just put together 2010 Ranger with a 4 cyl Duratec with auto trans.(built from a wreck)
I drove it for the first time today. That thing flies. The thing would make a Pinto fly also.
The only thing that keeps me from this swap is the oil pan. I see NO REASONABLE
solution for this. The boys from across the pond make a "tin" pan, but it is for a rear sump.
Anyone who knows of a reasonable plan I'd love to hear from you. I do know the trans
tunnel would have to be seriously modified to accommodate the trans, but does that thing
ever shift.
Rob3865
I read Duratec and got all excited. I thought you were talkin about one of these.
Regarding the $200 for the transmission; Pick Your Part wants $140 + $15 core + State tax (about $12 here) + their "environmental fee" which I'll estimate at about $10. That would be about $192 and you have to pull it yourself.
  They do have a monthly 50% off sale that would probably bring it down to about $110.  But if they don't have one during the sale period you can't really factor that.  I'd say your $200 cost is a decent price.
I haven't take the time to read all the links, but I recall years ago there were a few people in Australia that cast bellhousings to adapt a fair number of engines to different transmissions.
I could see a real market for a three piece, modular bellhousing.  The center section could have a common bolt pattern to the engine/transmission sections.  Then the bolt configuration at the bellhousing/transmission end pieces would only need to be a few inches deep and CNC'ed from a flat plate.  Sort of like the plate fits the engine, another plate fits the trans and a common bolt pattern center section bolts the two ends together.  There may be a need for a few different length center sections, but the minor differences can be made up in the end plates.
bbobcat75
1975 mercury bobcat 2.8 auto
tintmaster
Love this thread. Ironman, have you completed the conversion yet?
I have a '77 Pinto that I am wanting to do this swap in. But I want to use a C4, as I have bad hips and shifting is out. I plan on just doing the engine swap for now. Then gather everything to do a turbo. Also was wondering if this oil pan will work?
http://www.retro-ford.co.uk/shop/content/zetec-rwd-wet-sump-z007
I will be using a Megasquirt engine management. Unless I can get stock ECU and harness cheap enough.
C. Eugene Brown
There is becoming a lot of info on the web for this engine, but it is still relatively expensive.  Pintosopher, I believe this is the site you were referring to.  Hope these links work.
http://www.rwdmotorsport.com/index.php
While looking around found a few more interesting sites.
http://retroford.co.uk/shop2/index.php?cPath=22&osCsid=5493c520ec9970255b38027595685084
http://htperformance.net/index.php?page=shop.browse&category_id=11&option=com_virtuemart&Itemid=1
and the site referenced a page or two ago:
http://quad4rods.com/index.php?page=shop.browse&category_id=2&option=com_virtuemart&Itemid=100041
Cromcru &SRT
I can't get the link to attach and still open properly. Use the Search terms to locate and open the link from there.
SRT,
Similar products, But not the Co I had in mind. That site in your link is oriented towards Seven replicas. I'll try to get it Right and resend the link.
Quote from: cromcru on February 22, 2010, 10:11:41 PM
hey pintosopher what is the url for their website. i have had no luck in finding it.
I believe it's www.rwdmotorsports.co.uk  bit if that doesn't work try google and use Duratec conversion as the search terms. Their site was shut down until the 17th for " Holiday" It might be back up now.
cromcru
Hey Ironman,
Where are you on this project? Have you seen the Duratec goodies on RWD Motorsports UK website? They have the pan and Oil pickup made up. They also have the Bellhousings for different trans apps too.
Ironman, Please contact me. Thanks
Ironman
Quote from: dholvrsn on August 27, 2008, 08:18:29 PM
BTW, don't know if this helps but: http://shop.ebay.com/items/_W0QQ_fromZR46QQ_sopZ10?_nkw=miata+transmission&_fromfsb=0&_trksid=m270.l1311
Thanks for takin the time to look,..
I wish I could get what I need for those prices. Unfortunately the transmission has to come from a 2006 or newer, and would cost 2/3s of my budget.
Mick
Ironman
Ironman
Howdy all, I had a few days to ponder and do research,..
My original goal was to have a little twin cam light weight road rocket. That goal is still primary. Its definitely achievable if I throw enough money at it. But as this project progresses, I want more and more to make this a project thats in the affordability range to the average guy.
There is no way around the initial cost of the engine, transmission, or bellhousing, those are all big money Items that you simply have to step up for. They're total cost is a significant  part of the project. however there are three other major expenses,.. oil pan modifications, fuel delivery system, and ignition. those componets expense can easily dwarf the cost of the "running gear".
The Oil pan alone is quoted at 4+ hours weld time to make clearance and oil capacity mods, plus your own time making parts and getting it to the point its suitable for welding. It must be built on a jig, (or engine block) it must be stress relieved and then have the voids and crevices back filled with epoxy to promote smooth oil return. The Induction is a whole nother story, It can rapidly climb over $1,000.oo,.... in fact trying to stay under 1,000 using whats available is difficult, but not impossible.
There needed to be another way,.. I woke up one morning thinking about model cars, and it came to me. PLASTIC!!
(well kinda),...Polymers, (casting and laminating resins).
My valve cover is made of the stuff allready,.. and so is my intake.
I did some research and found resins that are stronger than aluminum that can withstand engine heats (for application) and chemicals, gas/oil/solvent.
And the cost for a gallon is less than one hour of welding. I am going to try and make a model of the oilpan I want,.. and make a mold. The beauty is I can design the sump anyway I choose to fit any application or volume of oil.
To solve the problem of expense in the induction department an intake manifold needs to be built that will accept a stock throttle body in the pinto chassis. This should be simplified a little since the stock manifold is a polymer, and can be cut down to yield a base plate that accepts stock sealing techniques, and a viable cross section to calculate runner taper. The result should be a very significant jump in hp with a very favorable side effect,.. the option to cut cost dramatically.
Using all oem parts would allow the use of the stock computer. At that point Painless Wiring could make you a harness for about $350 and flash your ECM for a performance update.No need for a stand alone system with a wide band o2 sensor. That route would still be available to anyone that wanted to wick even more hp, but the basic road rocket package could be achieved for several hundred dollars less, and give you easily obtainable inexpensive replacement parts.
I'm  guessing,.. but from what I've read that makes power in these engines, an improved intake manifold with an ECM mod to a stock system should be good for nearly 200 hp.
I'm going to try the polymer route,.. If I can produce a high quality part that I can replicate, it makes this conversion a more realistic option for anyone that would want to try it.
Mick
Ironman
Ironman
Quote from: dholvrsn on August 25, 2008, 03:09:48 PM
Take it that you can't find a Miata with tranny in the junk yard.
Found em,.. just cost 2/3 of my budget before shipping
Ironman
Ironman
It will be a couple years before miata trannys will be a cost effective alternative for a Duratec conversion.
Moving ahead with the specialized bellhousing.
Ironman
Ironman
Quote from: dholvrsn on August 24, 2008, 04:45:22 AM
So you are going to that *two* parts that are more expensive than that welded pan now....  :laugh:
Ok,.. maybe a couple parts might cost more.  :P
Ironman
So you are going to have *two* parts that are more expensive than that welded pan now....  :laugh:
Ironman
Quote from: dholvrsn on August 23, 2008, 04:38:04 PM
What's the other one?
Do they need to be thawed out coming from the great frigid north?
brrrrrrrrrrrr!
They had a five and a six speed. I'll try to reach them monday, I'm sure I wont even flinch at the price :reek:
Ironman
Ironman
I just got off the phone with a mazda parts locator,.. lol your gonna love this, he found only 2,.. and they are in Quebec.
But 1 is a 6 speed!!
Ironman
Ironman
Quote from: oldkayaker on August 23, 2008, 07:45:15 AM
This is a long shot but may be an alternative to the specialized bell housing.
This Wikipedia site indicates that the Duratec is a MZR family engine: http://en.wikipedia.org/wiki/Duratec
Another Wikipedia site sayes the MZR engine came in the Mazda MX-5 (third generation Miata, 2006 to present) which I believe is still rear wheel drive:  http://en.wikipedia.org/wiki/Mazda_MZR_engine#Duratec
This thread seems to indicate they are the same engine: http://www.good-win-racing.com/mazda-talk/viewtopic.php?t=795&highlight=mzr
If the above is correct, the Miata shifter should be in a better location.  Unfortunately finding that late a model car in the junk yard probably will be difficult and expensive.
Great tip Oldkayaker,..
I would guess that would be the way to go, if price isnt largely different from what I'm looking at now. I would think  the clutch issues would be easily resolved.
Ironman
apintonut
nice  :search: ,
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Ironman
Quote from: apintonut on August 22, 2008, 09:50:50 PM
how far off is the trans from bolting up?
I wont have the money for the bellhousing til sometime next week,.. Then however long it takes to ship.  Then I'll have to see what happens in the clutch department, flyweel etc.
The Focus flywheel probably wont work.
Man I wish I could embrace the the concept of my shifter being in the midle of my dash board :nocool:
Ironman
