71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 02/26/2017 03:22 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 05/19/2018 04:56 pm
Date: 02/05/2020 11:06 am
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
  • Online today: 1,459
  • Guests: 85
  • Total: 85
vintage Pinto lift and stabilizer kit
Started by Reed, August 06, 2008, 12:21:55 PM
Quote from: Pintony on August 07, 2008, 09:40:20 AM
G you must bee a fool to go ahead and buy this after all the bad things that have been said about this "KIT"... :P
Tony, I didn't buy it, after talking with you about it I didn't "consider" it again....
key word = consider
"I wanted others to see the info too in case they saw these and considered buying them like I did..."
Quote from: Pintony on August 06, 2008, 09:29:47 PM
Hey Bill,
I think I told Cookieboy the same EXACT thing word for word... :lol:
Too Funny!!!
Yes you did Tony, I thought that's what Bill would say too and was suggesting with the "run" statement. I wanted others to see the info too in case they saw these and considered buying them like I did...
Quote from: apintonut on August 07, 2008, 07:38:03 AM
I thought it was easier to follow than it was:
Quote from: 77turbopinto on August 06, 2008, 09:35:44 PM
Kool!
Hey, one of the Eagles landed here, I have to go get the other one in person.
Quote from: Pintony on August 06, 2008, 09:41:52 PM
Hey Bill,
Y do you have to go get it???
Quote from: 77turbopinto on August 07, 2008, 05:05:09 AM
This is hijack territory....
Because of what the insurance was on it, it needs to be signed for in person.
Just public PMs in code.....
I purchased (traded) some Pinto parts with Tony, and I was letting him know the details of the arivals of the different boxes (you know, critical world domination type stuff...).
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
apintonut
Quote from: 77turbopinto on August 06, 2008, 09:20:13 PM
I think higher rate coils would be better, like Mustang II V8 ones (cut to the correct hieght to avoid the suspention being toped out staticly). It appears that all that kit has is items that either jamb between the coils, or spacers under them; both can either damage the spring or come loose/out (not fun on the trail). Also, spacers like that can decrease the travel in the suspention vs. just having a better spring.
RUN FASTER......
i had a set of  v6 coils but cant find them (may have given them away)  but as u know it is better to have to many parts and option than not enough for 25$ to make it a drivable project is worth it
Kool!
Quote from: apintonut on August 06, 2008, 08:59:11 PM
hey bill always good info.
i however did not make it clear as to why i need the front up.  i scored a set of springs jeep i think may be ranger (they were in a pile from a guy that dose allot of 4x4 lifts)  for free with a 2" lift spring and some 1" longer shackles this could give the car up to 4" of lift (not on the car yet (so dont know))  but i want 2 thing for the car to se mostly level and to get the tallest tiers on the car as i can for clearance  on the roads we go camping on. the family pinto truckster  wagon.
ps the dirt track guys us lower A arms from fox body mustangs to camber out the wheel s but i need some to revers the the negative camber if i hafta lift more than a 1-2" in the front
RUN FASTER......
apintonut
Quote from: Cookieboy on August 06, 2008, 02:42:46 PM
yep... that's what I thought too when I saw it... thought it might be handy on the 78 which is getting low in the back, thought I could lift it up a bit vs. new leafs
Bill, what do you mean to suggest with "run....."
For the rear springs:
If a Pinto is getting low in the back it is most likely due to very worn, rotted, or cracked/broken springs. Installing longer shackles MIGHT lift the car, but it will also put more stress on them in a way they were not designed. (I remember friends installing the old "shackel kit" only to have the car to quickly return to the drooped look with the ends of the leafs bent down) The correct shackle length is also important to keeping the axle located in the suspension travel, thus effecting handling. A leaf, when pushed flat (loaded) will 'grow' in length, so the springs are angled with the rear higher to counteract most of the 'change'. Remember, the 'pin' where the axle is located on the spring is not centered. By moving the vertical location of the rear of the spring you could induce a serious 'roll-steer' under accel or decel. If a Pinto is sagging in the rear it should have good used, new, or re-newed springs installed, as well as a full inspection and replacement of any other parts that are bad. I have taken a few sets apart to build a good pair; very easy. If you don't have a pile of them around, there are race parts suppliers that sell Pinto springs, as well as custom spring places. If someone is looking for a way to carry extra loads in a Pinto, adding leafs is a much better way to go.
For the fronts:
If the front is droopy, get new aftermarket springs, or good used ones. If you need to get higher rate ones because of a swap, then find a different application.
Quote from: apintonut on August 06, 2008, 07:28:23 PM
thanx i just bout them!!! just what the 79 wagon needed im setting it up for trailer pulling ....
'Lifting' the rear of the car is not the same as 'increasing the load rating'.
Keep in mind that both the seller of that item and the manufacturer DON'T CARE if you wreck or damage your car, they just want your money.
RUN!!
apintonut
thanx i just bout them!!! just what the 79 wagon needed im setting it up for trailer pulling  ;)
i dont need right away so it may be coped for others.  ;D
Quote from: 77turbopinto on August 06, 2008, 02:23:47 PM
Looks like a lift kit: Coil spring spacers and longer shackles.
Run.....
I asked Tony about these recently... the impression he gave me is they are not worth having/installing/buying
Reed
Never seen anything like this before.  What's it for?
clickme
