74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 10/27/2018 03:30 pm
Date: 10/05/2017 02:26 pm
Date: 07/04/2017 03:26 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 02/03/2018 11:28 am
Date: 08/20/2017 01:34 pm
Date: 12/30/2022 01:30 pm
  • Online today: 529
  • Guests: 464
  • Total: 464
xmission
Started by Fred Morgan, August 06, 2008, 11:17:34 AM
Thanks again, hey come over here and help me pull parts I am getting behind. Fred   :)
Bill slow speed drill press  Fred    :)
Tony I know you did, thank you for the info.. Fred   :)   Just got off phone with nvrstock he wants wagon rear door it is a 74 he needs for 78 so will it work ?  ???
Quote from: Fred Morgan on August 21, 2008, 03:21:02 PM
....1.6 bell bolted to 2.3 after taking lower block bushing holes in 1.6 bell out to 5/8" and in 1/2"......
Or you could have used stepped dowels.
Did you drill them out with a hand held drill?
This was my repair, 2.3 bell will not bolt to 1.6 trans. 1.6 bell bolted to 2.3 after taking lower block bushing holes in 1.6 bell out to 5/8" and in 1/2". I instaled a resurfaced flywheel 2.3 old 1 missing teeth. Used the 1.6 smaller clutch dia. and the 2.3 press. plate. Changed drive shaft to smaller yoke dia.. Test drove all gears good and could not get clutch to slip so yea. Fred   :lol:
While we are on the topic of transmission problems...
Why might it sound like something is rattling around inside my transmission when I am just engaging the clutch while in reverse?
I prefer not to use that trans, when I got the car the trans was almost empty of gear oil + it falls out of reverse if I dont hold + it has 196,000 mi. on it so I was maybe thinking of trash can. The 1600 disc has 7/8" coverage on both sides of the 2.3 press. plate. The wagon has 160,000 mi. on it. decisions decisions oh my what to do. More input thanks Fred.  ??? :)
So if he goes about fixing it, and the trans is worn, how will it stop it from happening again?
Tony I know I talked a while back about 1600 clutch 1 having 20 and another having about 22. I dont know what route to take because I have so many parts. I have new 2.3 clutch assy. in box with flywheel, I have 1600 clutch or do I need to pull the square tire 74 wagon in hangar and pull what a hassle. So I guess I am trying to look for easiest way out, small disc I dont care I am not going to races, I mean hey I turned street corner shifting into 3rd, I putt in this car its my auto parts picker upper car. Reply thanks Fred.   ???
Tony I have 71 1600 trans with 63,000 mi. can I use bell from 74 2.3 and go with that.  Fred   ???
Dave it is all in tight, I was just getting ready to unscrew ? Fred   :)
Did the shifter come out of the transmission? It sounds like the retaining ring unscrewed itself from the transmission or broke and the shifter popped out of it's seat.
Going around corner down shift to 3rd, stick went a little farther to right than normal shifted forward now I am stuck in nuetral. Stick moves forward and back to center will not move to left ?  Fred   ??? ???
