  • Online today: 600
  • Guests: 541
  • Total: 541
Need A Part.. (79' Pinto!)
Started by hooshkin, August 04, 2008, 10:56:41 AM
pintopaul2003
what part of the wiring harness do you need?
we have a new addition to the pinto family
Hunter Daniel born nov 21 2006  5lbs 12.2 oz                     pintopaul@verizon.net
Thanks Tony! :)
Glad to see my close encounters with electrocution are paying off. :D
Most likey he asked because of the horn contacts. They may have shorted out and burned up the wiring. If driving around long enough with the burnt wiring and not knowing it, it may have melted other wires as well if the fuse failed to blow.
I'm not positive, but it's what I would assume since I've sparked the horn contacts several times when I have had to service my turn signal switch and/or steering shaft.
Pintony-
I am curious. Why did you ask if the op has replaced the steering wheel with an aftermarket one?
I have a 79 and am going to be doing that soon. Is there something I need to know before I do that?
Thanks,
hooshkin
The previous owner rigged the wiring around, and sort of messed up a lot of things. One day while I was taking the Pinto out for a test run in an open parking lot nearby our house, smoke starting rising from under the dashboard and some of the wires had melted off. There was quite a bit of smoke, but no fire. I'm clueless about the wiring stuff though but I was told by the guy working on my car I needed either the harness or diagram to change the wires.
And yes, may I see the diagrams incase I cannot find a harness at all?
Owner of 1979 Ford Pinto
hooshkin
Alrighty, I've tried ebay, didn't get much luck.. But i'm looking for a wiring harness for a 1979 Ford Pinto. I heard you can also use the wiring harness from a 79 mustang too, but I couldn't find one of those either. If any of you know where to get a wiring harness please let me know a.s.a.p.
If not, then any ideas where I can find some kind of old wiring diaghram?
Thanks ahead !
Hoosh!
