1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 02/28/2018 09:33 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 09/26/2019 05:31 pm
TWM Intake
Date: 08/15/2018 08:20 pm
Date: 04/10/2017 07:30 pm
Date: 02/08/2018 02:26 pm
Date: 09/06/2020 01:57 am
  • Online today: 292
  • Guests: 295
  • Total: 295
Ignition module
Started by JonzWagon, July 20, 2008, 10:19:47 PM
I never had that problem, but if I did, I would look for a shorted or bad wire(s), and I would change the dissy when I installed the new spark box.
I would not rule out the alt., the reg, or the igintion switch.
Is there eveidence of damaged or repaired wiring?
JonzWagon
Hello everyone, i need some advice.
I have an '80 wagon. 4cyl, automatic. Just messed up another ignition/computer box. I think.  Back in April I burned out the  original one.  The car starts then 10 seconds later dies. Then starts and a puff of white smoke comes up from under the hood right where the module is fastened to the fender, then dies.  Then starts up and runs for a while, but idles very rough.  The lfirst time this happened (in April) it wouldn't re start.  This time it will restart, however I am not sure how long it will continue to run.  My question is...has anyone else had this problem?? How did you fix it?  Can I get en after-market unit Such as one from Mallory? and be able to use it?  Any help or suggestions would be greatly appreciated.
  If I posted this question in the wrong place, my apologies,  Thanks, Jonzwagon
