I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 10/03/2018 10:46 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
72 pinto drag car
Date: 07/08/2017 08:25 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 08/02/2019 04:18 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
Date: 08/20/2017 01:34 pm
  • Online today: 367
  • Guests: 325
  • Total: 325
1973 Pinto
Started by fordsbyjay, August 02, 2004, 08:47:34 PM
76tanna
The tunnel and firewall definitely have to be modified.  I have a full cage to help with the strength of the body. I wouldn't have gone with a c6 except that I got a really good deal on it.  I had planned on the C4 but the C6 cost me less than rebuilding the C4.
PintoBro
Quote from: 76tanna on September 12, 2004, 06:30:21 PM
Thanks, I really appreciate the information.  I have the car ready for the motor (302 w/ 351 heads) and the trans (C6 w/ trans brake and 2800 stall). I' m glad I don't have to change the spindles.
What modifications did you do to get the C6 in there? Did you cut out the original tunnel and fabricate your own? I thought about going with the C6, but was told that the firewall and tunnel would have to be customized, and didn't want to sacrfice the regidity buy doing any cutting untill I could get a full frame under it. So I went with a built up C4.
Pintobro
71 Pinto 306 10.0:1 351w heads
Comp Cams: .554/.558 lift .294/.306 duration
Torquer II Intake - Holley 750 HP
Sepanek's Racing Transmissions C4 (Full Manual)
8" rear (4.62 spooled)
76tanna
PintoBro
Quote from: 76tanna on September 11, 2004, 08:47:54 PM
Do you have 5 lug rotors on the front?  I have a 73 and am wondering what to do about front wheels.
If your referring to my car, it has 4 lug up front, and 5 in the back. If your going to run it at the strip, If you run aluminum aftermarket wheels, they are going to require you to install the 3" long studs, and open ended lugs. They want to see the studs sticking out past the lugs. If you look at my previous post, and look up the part # for the Autodrags, you will get the correct wheel for the front, if you want to stay 4 lug.
Pintobro
76tanna
PintoBro
Quote from: V8pinto_306_n2o on September 02, 2004, 08:26:34 PM
Hey what size rims and tires do you have?  I am trying to get setup with big/littles and don't exactly know what fits.  Right now I have 265-50x14's on the rear and I'm unsure of the backspacing (I think it's around 4-4.5").  I want to go with a 15" tire about 10" wide but don't know what squeezes under there.  Also, I think I'm going with 15x4's up front.  Is there a specific backspacing or is the 15x4 some "standard" backspacing?
Shane
306 N2O Pinto
On the rear tires, if your referring to slicks, the biggest you can get under there is a 26 x 8.5 x 15 on a 15 x 8 rim with no more than 4.250 back spacing, if you don't want to butcher up the wheel well openings. Also, make sure you have the rear suspenson stiffened up a bit, cause if yours squat's on the launch, the lip of the fender well will rub the slick. I found out the hard way. As for the skinnies, I run the Moroso DS-2's (25.0 x 4.5 x 15) on Centerline  Autodrags. If you want to check them out, check this # on Jegs. For the rims, it's 184-055351442 and the DS-2's it's 710-17025.
Pintobro
V8pinto_306_n2o
Shane
306 N2O Pinto
 MMM ( Shiney)          ;D
fordsbyjay
Here is a picture of the blower.
Cuts heal, chicks dig scars, but glory lasts forever!
fordsbyjay
I have a '73 Pinto. It's been a V-8 car since 1981 so it is pretty good shape. It currently has a 89 5.0l shortblock with AFR 185 heads, victor jr., and comp hydraulic roller cam XE282HR, C4, 8" rear with 4.11:1, mini spool. It runs 12.50's which isn't bad for a street car. So last week I bought a BDS 6-71 for it.  ;D LOL. I hope to get it in by October so I can go to Years Ones Bristol Bash. Did anyone see that grey Pinto on e-bay last week with the 390 all under the hood. Sweet ride!
