Date: 01/23/2017 07:41 am
1976 pinto for sale
Date: 01/12/2017 02:08 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 05/28/2017 03:20 pm
77 pinto
Date: 08/22/2017 06:31 pm
Date: 09/22/2020 11:33 pm
Date: 12/30/2022 01:30 pm
Date: 08/30/2021 03:20 pm
  • Online today: 536
  • Guests: 489
  • Total: 489
Hey Tony, Your 1600 pinto
Started by Ironman, July 18, 2008, 12:39:57 AM
Quote from: 78squirewagon on July 19, 2008, 05:37:46 AM
You should drive one of them up to WI August 2nd ;D ;D
I vote for the Mustard Car! Join the Fun Tony!
or... maybe the red wagon...
Quote from: Pintony on July 19, 2008, 12:48:54 AM
Hello Mark,
What size tires do you need?
I should have the day off tuesday unless I get called in.
175/80R/13 or something that will fit a stock wheel. It might be Wednesday morning before I come through there or MAYBE Tuesday afternoon/evening. I am doing some work in Branson and a lot will depend on how that goes.
GREAT project by the way. You should drive one of them up to WI August 2nd ;D ;D
Pintony, get a hold of me if you could. I am going to be coming through St. Louis either Tuesday or Wednesday and if you have any good used tires, I need four  ;D
Mark
Ironman
Hey Pintony,
Great thread!!!
Man you do good work!! Your photos on rebuilding the back panel are very helpful. I'd like to know how you keep the sheetmetal from distorting when your welding?
Before I got into the junk buisness I was a welder for about 10 years.
On my own projects I've replaced sheet metal on bodys before,.. but I've allways disasembled them at the nearest factory pinch weld, spot welding them back together a few welds at a time and letting it cool. I tried working non supported sheetmetal on a 66 GTO once, and I did more harm than good. :mad:
Ironman
Ironman
Ironman
I just read where you had picked up a 1600 car,.. how is that project going?
Ironman
