1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 10/28/2018 08:45 am
Date: 09/17/2024 12:35 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Date: 02/27/2017 10:10 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 223
  • Guests: 208
  • Total: 208
Exploding Pinto recall fix?
Started by Reed, July 13, 2008, 12:03:09 AM
Reed
Well, I found 77turbopinto's previous post with its links to all the other threads about recalls and exploding gas tanks, and I feel fine about my Pinto now!  I have been a fan of 60s and 70s cars for years and have driven them without fear, and i will now do the same with my Pinto.  My Pinto does have the recall parts installed so I am set.   8)
Reed
Thanks!  I feel a bit better (safer) now.  I will search more and try and find those other threads.
I have seen crash test footage of a few early Pintos, but I have never seen one "EXPLODE".
This might be due in part to what could really happen to most any car if hit hard enough: The gas tank might get ruptured, leak, and then have a POSSIBILITY of ignition of the spilled gasoline.
NO CAR IS SAFE!! DON'T DRIVE!!
http://www.fordpinto.com/smf/index.php/topic,5283.msg31842.html#msg31842
That plastic shield is part of the recall fix for the 71.  According to the dealership guy that handled my recall, when the Pinto is rear ended hard, the gas tank gets pushed in to the rear end.  The plastic shield is suppose to prevent the sharp edges of the rear end from puncturing the gas tank and spilling gas.  Also part of the recall fix is a longer fill pipe.  The longer fill pipe is less likely pull out of the tank when the tank moves forward, again avoiding spilling gas.  There are a couple of past threads that go a lot deeper in to this topic and should be locateable with the search function.
Reed
I am still learning Pinto lore, but I was wondering (a) if Ford ever did a recall to address the gas tank problem and (b) what the fix was.  I am cutrious because onmy 71 there is a hard piece of plastic mounted between the front of the gas tank and the rear axle that looks to serve no purpose other than to be a shield.  Was this the Ford correction to the explosion problem?
I apologize in advance if this has been covered elsewhere.  I am still getting the hang of how to ue the eatures of this board.
