Date: 02/28/2018 09:18 am
Date: 10/03/2018 02:00 pm
Date: 10/14/2019 08:24 pm
Date: 05/13/2021 05:33 pm
V8 rear end
Date: 04/12/2018 10:57 am
1980 hood needed
Date: 04/23/2020 10:41 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 10/26/2020 03:24 pm
  • Online today: 507
  • Guests: 549
  • Total: 549
lifter removal
Started by lostandfound, December 20, 2005, 02:25:22 AM
The easy way that I do it is with a grease gun. Use a pointed fitting and inject grease into the holes next to each lifter. They will pop right out. Remove the grease and install new lifters. I have had some that you could lift the car with(broke apart with the vise-grip), but they just slide out with the grease, amazing.
johnsonracing
using a visegrip clamped on the lifter,( down from the top pivot area to prevent damage)tap on the bottom of visegrip with hammer to force the lifter up and out.You should buy a new set if you are doing any motor freshening.Cheap,should be able to get a set for under $40.00 at the right auto parts store.
   If you are putting in a new cam you have to buy new cam followers.This a must because the two parts have to wear-in together.
:o :o
lostandfound
i have removed the camshaft and all of the parts on the cylinder head but the lifters will not budge i can lift the cylinder head up  by picking it up by  the lifter
1979 2.3l sedan wooohooo
