Many Parts Listed Below
Date: 04/20/2018 11:15 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 10/04/2019 08:43 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 11/04/2018 02:34 am
Date: 02/08/2018 02:26 pm
Date: 07/21/2017 11:49 am
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
  • Online today: 548
  • Guests: 462
  • Total: 462
302 / AOD> will it fit?
Started by hoots, September 23, 2005, 01:20:28 PM
WOW!
Now that has to be the cleanest V8 install I have seen.
GREAT JOB!!!!!!!!!
hoots
Yeah, 302 with C4 tranny with the truck housing, no BFH required. It's quite the process of getting all parts in place. The tranny has to be installed from the bottom while the engine is lowered in place, without the exhaust manifolds on yet. Once the engine and tranny are bolted together then I lowered the unit to install the manifolds, then raised up to install the engine mounts. Here's some pics. Check in the 'Your Project' section here, I have a thread called 'work in progress'.
Hey Hoots!!!!Take some pick of your engine compartment. I wanna see how you did it. You have a 302 right?
it will fit with some clearancing from a BFH on the transtunnel. It is longer than a C4 and the mount will be further back a bit so a custom bracket would have to be fabbed up.
hoots
My C4 doesn't have long enough legs on the interstate. Has anyone installed the AOD (with the 302) in a Pinto?
