Date: 01/23/2023 02:22 pm
Date: 01/19/2021 03:56 pm
Date: 05/18/2020 10:22 pm
Date: 05/28/2017 03:20 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
V8 rear end
Date: 04/12/2018 10:57 am
  • Online today: 1,166
  • Guests: 99
  • Total: 99
Bleeding brakes
Started by Jdm071755, November 02, 2017, 04:35:06 PM
hotrodln
Glad you got your brake s sorted. My factory proportioning valve was leaking so I removed it and just put a T in the line for the front brakes, then an Adjustable bias valve for the back brakes. Now I can turn down  the rear brakes so they don't lock before the fronts. The bias adjuster was by Baer Brakes.
Quote from: dick1172762 on December 19, 2017, 01:32:21 PM
I was talking about your time at Comptech. Weren't you racing the Pinto then? And people were known to try different intakes while on the dyno.
I raced a Ford, but not while I was working there, I would have needed a Civic or S2000 or NSX to get those bennies... Too spendy to get Dyno time and I was a lowly shipping Guy :o
Quote from: dick1172762 on December 18, 2017, 04:59:58 PM
Is that the engine out of your Pinto on the company dyno?
LOL, look closely , It's injected, and I have no company, and my Dyno was in my race bucket seat and between my ears ;D
Thanks for the great rebuild thread, When I do my 72, I'll be reviewing this again
Pintosopher Biased towards proportions, but insisting on Stacked intakes ;D
Jdm071755
Ok guys brakes are all done. The leak from the brake warning switch was caused by a twisted oring when I reassemble the valve what I did was take it all apart  put all prongs back on. Dipped all parts in clean brake fluid and reassembled the valve. Brakes bled fine  no leaks
Joe
Yes it would be the same cause it has nothing to do with the front brakes. It could care less if the front brakes were drum or disc.
72s with both style brakes is in the same place.
Are you showing one on the frame just below the firewall? I think I remember them there.
Quote from: dick1172762 on December 06, 2017, 10:21:33 AM
I think on a Ford with drum brakes on the rear the propoptional valve is under the car in the brake line to the rear brakes. Its maybe 1" in diameter and 3" long.
Jdm071755
My brake light warning switch is leaking. It never gets tight just keeps spinning. Where can I get another one?
Joe
Jdm071755
Ok got the rebuilt valve in. Front brakes bled with no problem. Seem I have a slight leak from the switch.  After I fix the leak I'll move on to the rear
Joe
Jdm071755
Quote from: LongTimeFordMan on December 05, 2017, 05:37:27 PM
From some research and some conversations with  a local hotrodder I thi k the early cars only had the dual brake "safety valve" with the plunger that slides to redirect pressure to the opposite system, ie front or rear in the case of a catestrophic failure in one of the systems and to as well indicate the failure with the brake indicator light.
A true "propoptioning valve"  modulates the pressure to the rear wheels and usually has some sort of user adjustable screw or k ob to adjust the pressure to the rear wheels.
Most later cars and gm cars seem to have them integrated into the safety valve and have the adjuster screw.
There are aftermarket "proportioning valves" that cost between $15 and 50 that can be installed into rear brake line to adjust the pressure applied to the rear break system. there is a knob that allows for the adjustment to balance the pressure.
Do a google search for "universal adjustable proportioning valve"
As I mentioned above, I plan to do a 4 wheel brake job in january and have an aftermarket valve installed.
Ill post with the results.
Take pictures of your setup
Joe
Jdm071755
Take some pictures
Joe
LongTimeFordMan
Read my post again. It was intended to be a joke for pintosopher. I knew he would answer it with another joke. Such post keep us on our toes.
Jdm071755
Quote from: dick1172762 on December 01, 2017, 01:04:49 PM
Is your proportioned to the limit proportional valve have adjustable proportion or is your proportional valve non proportional?
There is no adjustments at all. When you put in the brass valve you center it on the switch hole the screw in the switch
Joe
Umm, Don't blow it all out of proportion! :o besides, I must have portion control when I eat too ;D
This is a really thorough informative rebuild, Keep it up, Inspiring too!
Pintosopher Proportioned to the limit , avoiding locked wheels and topics
Jdm071755
Quote from: dick1172762 on November 27, 2017, 11:32:56 AM
Take a look at the tech to rebuild the valve.    http://www.musclecarresearch.com/valve-rebuild-weatherhead-drum    Its for a different valve but the tech would be the same.
Cleaned all parts ran a .45 cal bite brush thru housing. Put on all seals and o-rings. Time to re assemble
Joe
Jdm071755
Quote from: Wittsend on November 26, 2017, 04:58:12 PM
Keep us updated on the outcome. What does the kit cost and where did you source it from?
https://www.musclecarresearch.com/valve-kit-kh-D7DZ
Joe
Looks like your going in the right direction. Keep us informed of your work.
Jdm071755
Quote from: Reeves1 on November 23, 2017, 07:22:40 AM
Agree !
I have one (off the blue 72) I was thinking of re-building.
Also thought I may go with an adjustable after market.
It will have a line lock when done as well......
Update. After soaking all parts in ammonia for 48 hours and rinsing with water the port shown and the one on the opposite side were clogged I took a fine paper clip and cleaned the out. Jut waiting on the rebuild kit.
Joe
Quote from: dick1172762 on November 22, 2017, 10:27:31 AM
Looks like you will fix your problem very soon. Keep at it. We will all learn from it.
Agree !
