Date: 10/25/2019 03:30 pm
1979 pinto
Date: 04/19/2018 02:02 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 04/25/2017 12:17 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 03/16/2017 10:00 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
  • Online today: 1,459
  • Guests: 874
  • Total: 874
Hood/Carb clearance and go fast
Started by lesterwa58, April 15, 2013, 07:19:00 PM
The triangle shape air cleaner with all the holes in the top, that Edelbrock sells will clear ever thing just fine. Cheap too.
tbucketjack
There is a low profile air cleaner with a drop down base that might work.
moonman
i have run an offy intake with a 390 holly 4 barrel and a mr gasket air filter for a year no problem.
streets the game, sneaks the game love to go fast in Little cars.
Yes, the post is old, but I'd be curious to know how much trouble came of using the Motorcraft 2 bbl., if it is a 2100 or 2150. Should have some fits there with too rich due to power valve issues, depending on which carb used.
waldo786
I'm curious about this too.  I have an offenhauser dual port intake with a fuel injection set up from FAST.  I'm hoping it all fits underneath the hood.  Planning on having the heads done at BoPort racing and a roller cam as well.
lesterwa58
I am installing a Motorcraft/Ford 2 barrel carburator on an Offenhauser intake manifold in my 1980 Pinto with a 2300 engine, will I have a problem with hood clearance, and if so what can I do to allow the hood close normally?  If I need to modify the hood, where/who might I go to for another hood?  Without going into the engine, other than the top part, what can I do further to give me more go power?  I have the Offenhauser intake manifold and carb, an exhaust header and a roller cam with a competition grind?  Please respond to me via my e-mail address, which is: lesterwa58@yahoo.com
