Date: 04/20/2017 10:10 am
Early 2.0 engines
Date: 05/09/2018 12:45 pm
Date: 12/31/2017 11:14 pm
Date: 05/19/2018 04:56 pm
Date: 02/04/2018 08:26 am
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 12/13/2016 10:25 am
  • Online today: 1,459
  • Guests: 156
  • Total: 156
Hood/Carb clearance and go fast
Started by lesterwa58, April 15, 2013, 07:19:00 PM
The triangle shape air cleaner with all the holes in the top, that Edelbrock sells will clear ever thing just fine. Cheap too.
tbucketjack
There is a low profile air cleaner with a drop down base that might work.
moonman
i have run an offy intake with a 390 holly 4 barrel and a mr gasket air filter for a year no problem.
streets the game, sneaks the game love to go fast in Little cars.
Yes, the post is old, but I'd be curious to know how much trouble came of using the Motorcraft 2 bbl., if it is a 2100 or 2150. Should have some fits there with too rich due to power valve issues, depending on which carb used.
waldo786
I'm curious about this too.  I have an offenhauser dual port intake with a fuel injection set up from FAST.  I'm hoping it all fits underneath the hood.  Planning on having the heads done at BoPort racing and a roller cam as well.
lesterwa58
I am installing a Motorcraft/Ford 2 barrel carburator on an Offenhauser intake manifold in my 1980 Pinto with a 2300 engine, will I have a problem with hood clearance, and if so what can I do to allow the hood close normally?  If I need to modify the hood, where/who might I go to for another hood?  Without going into the engine, other than the top part, what can I do further to give me more go power?  I have the Offenhauser intake manifold and carb, an exhaust header and a roller cam with a competition grind?  Please respond to me via my e-mail address, which is: lesterwa58@yahoo.com
