Date: 01/30/2017 01:48 pm
Date: 12/31/2017 11:14 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 08/01/2018 01:27 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
  • Online today: 502
  • Guests: 488
  • Total: 488
Fuel Line Placement
Started by From_Jonah, December 07, 2013, 02:19:18 PM
From_Jonah
That's awesome. That article helps me a ton. Timing confuses me but that clears it up a lot.
There's no mark on the aux gear(at least mine don't have one)at TDC the rotor on the distributor needs to be lined up with #1 plug wire.
Clydesdale80
I believe the aux. marker goes straight up
Bought a 1978 hatchback to be my first car.
From_Jonah
Okay awesome! Do I line up the aux pointer with the string too?
Clydesdale80
do you have timing belt cover and pointer or not?  if so, line up the mark on the cam gear with the pointer while the crank is at TDC. If you don't have a pointer, use a string to make a straight line between the center of the cam gear and the center of the auxiliary gear.  line up the mark on the cam gear with the string while the crank is at TDC
From_Jonah
Also, I think my belt timing is off. I have a hard time understanding timing, and where my sprockets need to go and such so any help in that area would be super greatly appreciated.
From_Jonah
So, I'm almost done with the engine rebuild in my '80. I've got the motor back in the car and almost everything is hooked up but I've lost the pictures I had of where the fuel lines run and one of them broke when I was re installing the motor.
Could someone possibly either take pictures or send me a diagram of where the line go?
Thanks!
