Date: 08/03/2017 07:40 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 08/22/2017 09:21 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 11/11/2019 04:49 pm
windshield
Date: 04/14/2018 08:53 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 09/21/2018 11:35 am
  • Online today: 515
  • Guests: 452
  • Total: 452
2.8 Temp Problem, NEED HELP!
Started by Pintopower, January 30, 2009, 01:44:43 PM
78txpony
What type or brand of t-stats were you using?  Did you change them all with the same style / brand?
At this point I would have put the old one back in to see what happens.
Recon a piece of old gasket or something is stuck in the block somewhere?  A reverse flush with a garden hose could dislodge something like that.
Yes, I would be just as PO'ed than you are by this point!  (or :drunk: instead...)
-Rob Young
1997 H-D Sportster
firepinto
I know on my dads old 2.8 Broncos, having the Tstat on the bottom of the block caused problems.  He would drill a small hole in the Tstat to keep the block from vapor locking.  When he filled it with coolant he would squeeze the top radiator hose to try and work the air out of the block.
'79 Pinto auto hatch back with an '80 2.3L and 4 speed transplant.  A 2.3 Turbo and T5 are waiting for the next transplant.
Plans changed, going V8 with TKX!
Pintopower -
  Did you ever get this issue resolved, or are you after a 302 at this point?
Pintopower
I'm at a loss. I gave up and brought the car to a great radiator shop that only deals in automotive cooling. It's been two weeks. They have no idea.
They did the following:
1. Coolant test to exhaust gasses.
2. Thermostat
3. Chemical flush
4. Radiator cleaning
5. 3 mixtures of coolant
Now, like starliner and phils toys have mentioned, I am picking her up and trying the water pump. Who knows at this point.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Starliner
I have seen Pontiac gig block water pumps where the clearances for the vanes was too large.
Why not change the water pump for the heck of it.
I always buy new instead of rebuilt.
Also check the timing cover as you change the water pump for any issues.
Corrosion, blocked passages, The pump sits the correct depth, etc.
Also check that your battery is charging properly and the belt is not loose.
Low battery voltage makes the gauge read low, slipping could effect the water pump.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
I would lean toward a bad water pump  I just changed one on my 96 tauras with a 3.0L had similar problems no heat at idle and over  heating  unless the rpms were high . i changed the thermostat, flushed the heated core , and lived with it for almost 2 years not driving much in the cold or long distances. Changed the water  pump and  no  over heating  and i have heat in about 3 minutes.(around here as long as it takes to clear the  snow  off the car) and have taken  several  longer rides .
Starliner
For oil, try Mobil 1 15W-50.    It can take the heat and the cool.   Also has enough ZDDP for the cam.
Did you try using Redline water wetter in the cooling system?
Is your heater core plumbed correctly to the engine?
the 2.8l motors are known ( even at regular oil changes) to have the oil galleys and other oiling areas are prone to plugging up. which can cause low oil pressure and over heating as well.
Pintopower
Hmmm... Well, I do know that my oil pressure gauge reads 60psi at highway speeds... but I have had problems on poorly maintained engines like you stated above. What the heck, she's due for an oil change any way...
PintoPower,
Bear with me on this suggestion, first some relatable circumstances:
1978 Mustang II Cobra 2.8 with auto trans , Girlfriend's car ,I assumed was maintained at a minimum with fluid changes.
It overheats one day, I replace Thermostat and Anti-freeze, It overheats again within 5 minutes and water pump begins leaking. I replace waterpump and recheck thermostat placement, It overheats again before I can leave the driveway.
I'm really puzzled I ask about recent maintenance, pull the dipstick and am blown away by the oil condition (Sludge) I Pull the battery and go after the oil filter, It weighs almost 4 lbs and is nearly blocked, I change the oil install new filter and Viola! No more instant overheating.
The Oil pressure sender didn't give away the problem, but the damage to the rings had been done, it puffed blue on the trans shift points and started to use a bit of oil. But the Engine might have just needed a real thorough PCV cleaning and breather service.
Your engine is obviously better maintained, but possibly you have a failed Filter by pass and resultant lubrication issue, or maybe junk in the sump that's starving the pickup or plugged a galley in the block?
My two cents, hope it helps
Pintopower
Starliner:
The gauge in the car is after market, not the rallye pack. I have made sure it was working correctly by means of a temp gun. As for teflon tape, I do not use that. I use silicon sealant. I tell you, this is pissing me off. I have never had such problems with this engine.
Starliner
On my old 77 Cougar, my factory temperature gauge read cooler than normal when the interior was cool.  It would then read higher than normal when the interior was hot.   Running the heater, dash lights, or summer weather had it indicating it was hot.  For the longest time I thought it was my engine.
Later I added an aftermarket gauge with the sensor in another location in the intake manifold so both gauges were operational.  The factory gauge was the problem.
Another thing to look at..  If you removed & installed the temperature gauge sensor and used teflon tape, that could create a high resistance ground path.
Pintopower
beegle55:
If the radiator were plugged, that would not account for the long time it takes to warm up as on this engine, water does not flow through the radiator until the engine warms up, plus the radiator is cooling great, 200 at the top and 70 at the bottom. What that is telling me is that the system is not flowing through the engine; it is passing through the radiator way to slow. When I used the temp gun on the radiator, it is cooling very even. The radiator is new, as is the coolant. The temp sender was the first thing I checked too.
75bobcatv6:
I agree, it the engine should be at operating temp in about 4-5 min. I think there is a block in the engine as well, that is causing water to not flow well, and that would affect the temp sender IF hot water is not getting to it. That would give the illusion that the car is not heating up fast enough, when it actually is. I know the radiator is clean (trust me, you could drink the coolant in my cars engine it's so clean) but that does not mean that after that giant pot hole I hit something nasty wasn't jarred loose in the engine 150K mile since rebuild engine.
turbo74pinto:
It is not a stupid question. I from all the pintos and fiats I have built, half of the thermostats were in backwards. On the 2.8, the thermostat housing is to short to allow the thermostat to go in backwards. To check for exhaust, I have a sample of coolant to the radiator shop. They tested it for me and it was clean. I am however, intrigued buy the spinning impeller.... That would account for poor flow and if the engine water is not moved around enough while the car is warming up, may not sent hot water to the temp sensor. As for an air bubble... I know these damn 2.8's LOVE them. I use a pressure tester when I fill them to pump water through the system. I have filled 2.8 dozens of times with out a problem. I can't imagine why this time it wont get the bubble out.
71pintoracer :
Prior to me changing the gasket and falling into the massive pothole, the car ran perfect. Idled at 185 ish and ran on the highway at 180 ish. In traffic on a hot day with the a/c on, at 195 ish. So yes, either me changing the thermostat, which I have done a ton of times caused the problem, or the massive pothole that made the car damn near jump into the air caused the problem. The thermostat is not in backwards as it wont fit and I am aware of the air bubble but have always been able to bleed them out with out a problem. I have also added coolant after letting it run and then cool off.
Starliner:
The car does have a temp gauge which is working correctly. I used my volt meter with temp transducer to verify, plus I used my Raytek temp gun. The engine has a good ground as well. The antifreeze was changed when I did the thermostat for the third time. I used 40 coolant/60 De-ionized water (which I have to order from work)
TIGGER:
You are totally correct. Sadly, I did that this weekend. I think it's worse now. I made sure for the 3rd time that the thermostat area was clean. The bypass hose was clean also. Down there, nothing is blocking anything.
Course of action:
1. I am going to disconnect the water pump belt. This should cause the engine to heat up rapidly BUT of the temp gauge does not show that then the engine is indeed heating up as it should but the lack of flow is causing the temp sensor to give a false reading. I will monitor the engines temperature with a couple to thermocouples, a voltmeter and a temp gun so it wont get hot and blow up (which would ironically solve the heating problem). This would prove there is a heating problem.
2. Reattach belt and allow car to run. Check engine temp all over the engine. The temp should be fairly uniform and if there is a blockage (I think there is one at the top of the motor near the water outlet which is the same place as the water bypass) the temp of that area will vary drastically.
3. Have the system chemically power flushed. The radiator shop I use has turned corrosive cooling systems in cars I have bought into ones that will take well over two years to munch through a sacrificial anode. That WILL get all the crap out of the system for sure.
The only thing all this will not confirm will be what turbo74pinto  brought up about the slipping water pump impeller. This brings us to number four
4. Problem is not solved, purchase hi-po 302 and use the 2.8 to send Johnny Looselips to the bottom of the ocean.
Thanks for the input guys, see why this is pissing me off?
I would maybe flush the system using a tee and a water hose to get any crud out of the system.  My shop teacher always said to go back to the basics.  I am not too familiar with the 2.8's however could something have gotten blocked or messsed up when you changed the bypass gasket?  That is the only other thing that changed that could be causing you problems.  Just a thought.  Good luck to you.
Starliner
I would start with installing a new aftermarket temperature gauge.
That would rule out if you are getting inaccurate information.
Also check that your engine has a good chassis ground.
I would change your antifreeze again.  You must have a 50/50 mix.
If you have too much antifreeze, it will act just like you said.
Too much anti-freeze will make it run hot.
My question is, was it working/running fine before you changed the stat? I'm assuming it was because you said you changed it because of a leak, not a heating problem. Therefore, you caused the problem when you changed the stat. I suspect the stat may be in backwards like turbo said,or an air pocket, the V6's were notorious for this, mainly because the stat is in the lower hose. I used to fill the coolant through the heater hose with the front of the car jacked up. Many times I would also have to let the car heat up, cool down and add more coolant the same way, 2 or 3 times before it would get all of the air out.
turbo74pinto
this may be a stupid question, but is the thermostat in backwards?  also, what are you using to test for exhaust gases?  im asking because the system i use, and the only i know of for that matter, uses a blue fluid in a turkey baster looking thing.  you zoop the air from the radiator and if there are exhaust gasses in the radiator, it turns the fluid either green or yellow.  also, for what its worth, contours had a problem with the impeller of the water pump spinning on its shaft.  it was caused, normally, from the impeller cracking.  it would do the same thing at times.
also, a big air bubble will do the exact same thing.
bob
bob
A blockage in the radiator can cause slow warming as the system isn't circulating fluids correctly to entirely warm the engine in a timely manner.
sounds like a blockage in either the water jackets or the radiator that moves after a bit and allows coolant to move but gets stuck again causing it to over heat.
As far as it taking 15 min to heat up to op temp i have no idea, a motor once on should be at op temp within 4-7 min depending on how you are on the throttle.
After further thinking I'd say it almost has to be a blockage in the radiator causing most if not all your problems. Poor circulation can also have an adverse effect on the proper warming of the engine, the cooling system deals with more than just cooling, it can also effect how the engine temperature is effected overall. I'd change out the radiator and put fresh antifreeze in it and see what happens.
It sounds like its a problem within the radiator itself. If it isn't a blockage/internal problem in the radiator causing the main overheating at low RPM's, it sounds like an electrical problem. It could be a combination of both. The uneven temperature of the radiator suggests uneven flow. The high temps at low RPM also suggests a restriction of sorts that is only overcome by revving the engine. The other minor problems could be set off by a sort of elec problem such as bad sending unit, if the thermostat is fine.
Pintopower
Ok, I swear to god I have had it. Here is the deal: A couple months ago my steering rack went out. I rebuilt it, the pump and replaced the lines. While there I noticed the thermostat housing was leaking coolant so I decided to change it. I bought a new housing and thermostat and installed them like I have done many times before, plus I changed the bypass gasket behind the timing cas that is held on with the (stainless) water pump housing bolts. I am VERY familiar with this engine and have built several. The first drive I went out on after doing that work I hit a pot hole that damaged a wheel. I do not know if the car was having the heating problems before or not as I did not look at the temp gauge. I simply did not want to leave anything out of the story. Anyway, when I pulled over after hitting the pot hole, the car started boiling over. It was 40 degrees that night. Then I drove home and the temp gauge hit 220. I limped her home and have had problems ever since. Here is what the care is doing.
1. Takes for ever to heat up; would normally hit operating temp in 3-5 min, now takes over 15.
2. Will not regulate its temperature; temp is all over the place.
3. Water coming in from the bottom of the radiatior is 70 degrees and at the top it is 200+.
4. Highway driving, the car stays at 195. The minute you lower the RPM, it raises FAST. All you need to do is drop her in neutral, raise the RPM and it drops.
Here is what I have done:
1. I thought it was a thermostat. Changed it 2 times. NOT THE THERMOSTAT
2. Thought the water pump may have gone bad. Took it off. ITS FINE
3. Noticed the .113 smaller diameter of the input outlet of the new thermostat housing and the 40% smaller input of the heater core line. Thta would NOT ACCOUNT FOR THE CAR NOT GETTING HOT FAST ENOUGH, plus the car should run cool enough without the heater core being used.
4. Maybe there is bad flow? THAT WOULD NOT ACCOUNT FOR THE CAR NOT GETTING HOT FAST ENOUGH, but might seem like that if the temp sender area is not getting hot water? Maybe there is bad flow in the engine/blockage?
5. Plug in the cooling system? THAT WOULD NOT ACCOUNT FOR THE CAR NOT GETTING HOT FAST ENOUGH, unless the temp sender (at the water outlet) is just not getting hot enough water as stated above (temp gauge is accurate, I double checked with a temp gun).
6. Plugged heater core? THAT WOULD NOT ACCOUNT FOR THE CAR NOT GETTING HOT FAST ENOUGH
7. Checked coolant for signs of exhaust in the water or oil. CLEAN (took water sample and used a test kit).
8. Pressure test across all cylinders, ALL +/- 5 PSI
9. Timing is at +20 BUT it has always been and THAT WOULD NOT ACCOUNT FOR THE CAR NOT GETTING HOT FAST ENOUGH
10. Prior to this, the car idled with the A/C on in 110 degree weather at 195 and ran at 185 on the highway.
11. No, the car does NOT have a fan shroud, nor will it ever get one. It has a massive aluminum radiator and plastic flex fan. It will zoop your hand to the condensor so I think the CFM is fine.
12. Coolant is changed every year on all my cars.
13. Oil is 500 miled new.
Is there something I forgot? Does any one know of anything I missed? Any ideas? I am at a loss here people.
Alberto
P.S. NO, I an not changing the engine out for a 2.3 or 302.
