77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 07/04/2022 07:55 pm
Date: 03/25/2019 09:02 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
  • Total Topics: 16,268
  • Online today: 190
  • Guests: 143
  • Total: 143
2.3l intake manifold ?
Started by hoots, March 23, 2006, 09:21:55 AM
rbohm
it has been awhile since i have seen it, but there used to be someone that made an adaptor that bolts to the 2.3 head, and allows the use of early 2.0 intakes.
64 falcon
66 mustang
82 fairmont
a man's fate is a man's fate
and life is but an illusion
fordsix.com admin
fast34
Are you still interested 77turbo???  Jeff (hoots) said they decided they did not need so it's still available if you want.
fast34
Just sent you a PM.  I would use the 350 or the Motorcraft 2100 2 barrel.
hoots
I'll take it. Can you send me your contact info.
What carb did you use? I've been looking at 350 Holleys. Or is there a more efficient one you would recommend?
fast34
If any of you want the Offy, give me a PM.  I'll take $75 plus shipping.  I have ground off all I.D. markings seeing as I was "supposed" to be using a stock OEM, so it is pretty much just a smooth surface.  I also know a friend that has a Offy 4 barrel for a 2.0 if anyone is interestred, $100 plus for that one.
pintoracer02
The offy intake sounds like a better deal to me.  I have a buddy with one and he likes it pretty well.
Bass Ackwards
pintoracer02
You might have a few hood clearance issues with the later type lower efi manifold and an adapter on a pinto. I know our race car cant have one with out a hole in the hood or a hood scoop and that is not allowed at Vernon.
Bass Ackwards
J.D. LARAMEE
Install the late model d-port efi intake with a carb adapter, available from Race Engineering or essl. This combo  flows better than the oval port intake to oval port head anyway and works very well on the street and looks better to boot.,J.D.
Home of the worlds fastest  pinto's
1977 Full weight 4cyl. Street pinto Blow thru c-s carb.
60ft 1.31
1/8 5.77 @ 128
1/4 9.43@ 141.03
77 Chrome moly 4cyl. Race Pinto- Blowing thru 2 C-S Specialties Carbs.
60ft 1.19
1/8 5.26 @138 1/4 8.22 @ 161
http://www.youtube.com/watch?v=3e-kxluQL
fast34
I've got a dual-plane Offy manifold with the 2 barrel mounting flange, Let me know if your interested.
hoots
Called both of those places, neither have anything designed for street. We'll make due with the OEM parts for now.
pintoracer02
call esslinger or racerwalsh
thats the only two dustributers that i know of.
Bass Ackwards
hoots
Need some assistance on replacing the OEM intake on a 2.3l. Haven't been able to find an aftermarket intake. The original had the CA smog relalted ports, just trying to clean up the looks and simplify the project. The carb is going to be a Holley 350CFM EC.
The ports are the Oval type.
