Date: 12/10/2017 01:14 pm
Date: 03/17/2019 03:57 am
Date: 09/03/2018 08:58 am
Date: 05/22/2018 01:54 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 04/12/2017 08:15 am
72 pinto drag car
Date: 07/08/2017 08:53 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
  • Online today: 2,567
  • Users: 1
  • Guests: 2205
  • Total: 2206
  • arkyt
gas milage
Started by JoeBob, August 25, 2011, 11:39:54 PM
Starliner
This message thread got me interested in my mileage again.
As I drive over 100 miles a day to & from work I always track my mileage and have the opportunity to experiment and get good data.
Up to now I have used the stock air filter housing system that pre-heats the air to eliminate carburetor icing in the winter time.  I kept that in place because I winter drive this car and the 1600 has unusual mounting.   (fire arrestor, brackets, and a carb vent)  No aftermarket fits.
Last week I took another air filter lid that i had (it has the snap on plastic lid) and cut some holes in the top to get cooler air.   My mileage is now 35mpg at 70mph and 42mpg at 55mph.   And this even though some hot air from the preheat can still.    Next I tried to make more holes and it broke.     So I put the stock air cleaner cover back on.
It should even get better if I plumbed an air cleaner to get cooler air ahead of the radiator and eliminate the pre-heat.
I will start searching for a complete 1600 air cleaner assembly to modify.  I could use it until Halloween and next spring.
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
back when i was driving one in the early 70's mine, with a turbo, and street/strip/freeway miles to the tune of about 40,000 a year was getting 24 mpg
(and i ran the snot out of it!)
My car got somewhere around 28 mpg  +/- 10% when I was coming back from Carlisle. The speedo is about 7-10mph off so the exact mileage is not known. Either way it is better than my v6 Chevy Malibu Maxx. It just depends what kind of condition the car is in. My car has had the engine & fuel system gone over so it's pretty much in tune considering its age.
fast64ranchero
My 71 w/2000cc and C-4 gave me 26 combined 30% city and 70%Freeway, my 73 with the 5 speed T-9 is at 31-32mpg
72 old V-8 parts Pinto
73 pinto, the nice one...
postalpony
Cruising back from Carlisle at 65-70 the Ol' Mail Wagon gave
back 33.6 mpg.  This car gets better mileage when I run It hard.
It likes 3000-3500 rpm.  Its just the way I have 'things' set up.
Hope to see old friends  9/11 in Macedonia !!
                    Later-----Dick
Now all we do is HAUL!
JohnW
I get 24-26 around town and a hair over 29 highway with an '80 2.3 4 speed hatchback.  29 highway is at 55.
Starliner
Ha!   My ugly 73 beater Pinto has a 1600 stick shift.  It gets 33 mpg at 70 and 40 mpg at 55.
I drive it 110 miles a day through Detroit, even in winter.  That is why the rust is starting to take hold.
I will probably take it to the Ohio event even though it is not much to look at.  But the engine looks good!
Here is what I did to get that great gas mileage:
1.  I changed to 15" rims & tires and it gives me 10% overdrive.  (Before I has even taller tires for 20% overdrive, but they would rub)  I verified my speed and overdrive by using an online calculator and my Garmin GPS.
2.  I added an electric radiator fan and removed the mechanical fan.  The electric fan only comes on when caught at a dead stop for more than 5 minutes.
3.  I added a Mallory 4758101 electronic distributor.  It has a better advance curve besides the better spark.
4.  I use Bosch 4016 platinum plugs.  Make sure to torque them as the box says.  Over torque and they run bad!
5.  Mobil 1 oil
6.  I rejetted my carburetor.  (actually had to jet it richer)
7. I added a front and rear spoiler for less drag.
8. I got rid of any junk that added weight  (no charcoal recirculation system, no spare tire, etc)
9. I smoothed the inside of the exhaust manifold and added a turbo muffler.
Keep in mind that my engine is a 1600.
Wifey has a 1979 2300 that I will reseal the engine over the winter and do some modifications.  So either later this winter or next spring I will see what mileage we can squeeze out of a 2300 with an automatic.
Quote from: oldkayaker on August 26, 2011, 07:01:38 AM
According to the Car and Driver mileage article, the 74 Pinto got 15.4 mpg.
http://www.metrompg.com/posts/crisis-fighter-pinto.htm
This link will probably expire but it gives the full text of the original article for some reason.
http://cgi.ebay.com/ebaymotors/1974-FORD-PINTO-Crisis-Fighter-ORIGINAL-1974-ARTICLE-/350168538404
That sounds realistic to me... my original '74 never broke the 19 mpg barrier, even on a trip.  With gasoline selling for less than 40 cents per gallon, it really wasn't an issue although I thought it was disappointing, considering the size of the car.  On the other hand, my current '72 got just about 30 mpg on the trip home from Hagertown MD when I bought it.  It is equipped with the 1600 cc/4 spd. combination.
I get 25 with a 5 speed, 94 2.3, 2500 carb. with headers in a 73.  Fred   :)
My 73 wagon with 2.0L 4cyl and C4 auto trans is getting about 23 MPG in city and about 28 MPG on the freeway. My 78 Sedan with 2.3L 4cyl and stock 4spd trans is getting 25-28 MPG in town (depending on how hard I drive it), and 33-35 MPG on the freeway.
My 73 is completely stock with everything connected appropriately.
My 78 has the EGR removed and blocked off, with the distributor connected directly to the primary vacuum source and not the carb where it is supposedly supposed to be connected. I also have the motor bored .020 over (thus slightly over sized pistons), but everything else is stock aside from the cam which I swapped out for a stock 91 mustang roller cam. Timing is advanced slightly and I have it tuned toward the lean side with no ill effects to drivability or acceleration.
ahawes
I've got my Pinto that's basically all stock as of right now with a 2.0 and 4 spd and I'm consistently getting 29 or so mpg, and that's with driving it fairly hard as well.
71 Runabout
JoeBob
The only frame of reference I have for gas mileage is in eBay. All these folks selling pintos that get 25-35 mpg. I am not even close to that. My 2.3 bob gets 20. I don't know highway mpg as I don't go anywhere. Tell us your honest mileage. Not just for the 2.3 but for all four stock engines. I am sure others would like to know. Any ideas that have worked to improve mileage would be appreciated.
77 yellow Bobcat hatchback
Deuteronomy 7:9
