Shiny is Good! => Your Project => Topic started by: johnbigman2011 on September 11, 2012, 07:10:28 PM
1. 8" rear axle to a 5 lug rear axle.
2. 11" brakes in the back
3. brake drums are new
4. wheel cylinders are new
5. all hardware kits are new
6. new axle bearings and seals when i put the rear end in the car
7. battery mounted in the back of the vehicle with heavy cables for the electrical
8. fuel tank has the fuel pump mounted in it it is a walbro.
9. fuel lines are from aeromotive and are larger than the car would ever need.
10. new u joints in the drive shaft
11. fly wheel turned and put a new clutch in it
12 front under carriage is new, all ball joints, all bushings, shocks, tie rod ends, rack and pinion.
13. coil springs up front are for a v6 with air
14. the front disc brakes are 11.5 " with a gm caliber.
15. turbo rebuilt 2 years ago, it did not need it but I had it done
16. msd al6 box for the ignition
17. nology spark plug wires.
18. new freeze plugs in it and oil pump and timing belt.
19. rear gear in the 8" is a 3.00 gear
20. motor and transmission came out of 1985 thunderbird turbo coupe
21. intercooler on.. the motor did not come with it, i added it. came off a 87 thunderbird
22. STILL NEEDS RADIATOR OVERFLOW. NEVER MOUNTED ONE
23. it does have a boost gauge, and it does work. does make 10 pounds of boost
24. transmission is a 5 speed.
25. has a stock bore and stock trw pistons
John my tow guy picked up the wrong wagon it should have been that one ! Fred lol
keep the timing at 10 btdc and upthe boost to 15lbs and have fun bustin peoples egos...also fora little more a la series ecu with big vam and 36lb injectors is a nice upgrade over the 30 lb small vam setup.... unless you had a late 85 with small vam and 36 lb injectors....i f thats the case just follow the first line in this... have fun.... i do....
Thanks Fred sorry... Left the wrong one didn't realize it till I had it loaded and it was just to hot to unload it.
Pinturbo75 Turbos are new to me for sure. I just couldn't stand reading all the fun you turbo guys have with yours, so I had to have one..
Where do I go about getting the parts you listed and how do you turn boost up. Are they bolt on and plug in items?
It's pretty fast now! I could only imagine what a few upgrades would do for it.
google (gillis valve), that takes care of upping the boost.... take a look at your injectors and see if the body is green(30 lb) or brown (36 lb) ..... also look at the tag on the ecu near where it plugs into the harness..... it should have a #and letter combo like, pc1, pk1......la3, 8ua... let us know what those are and wi can let you know what you have and can do...
Thanks for stopping by.
Racer, the wife wanted to see northern AZ, NM, and TX so we didn't come back across your way..
I'm making another run out west in October.. Are you still wanting the parts.
And yes, I owe you a hand shake.
