Welcome to FordPinto.com, The home of the PCCA => Pinto FAQ => Topic started by: lesterwa58 on April 15, 2013, 07:19:00 PM
I am installing a Motorcraft/Ford 2 barrel carburator on an Offenhauser intake manifold in my 1980 Pinto with a 2300 engine, will I have a problem with hood clearance, and if so what can I do to allow the hood close normally? If I need to modify the hood, where/who might I go to for another hood? Without going into the engine, other than the top part, what can I do further to give me more go power? I have the Offenhauser intake manifold and carb, an exhaust header and a roller cam with a competition grind? Please respond to me via my e-mail address, which is: lesterwa58@yahoo.com (lesterwa58@yahoo.com)
I'm curious about this too. I have an offenhauser dual port intake with a fuel injection set up from FAST. I'm hoping it all fits underneath the hood. Planning on having the heads done at BoPort racing and a roller cam as well.
Yes, the post is old, but I'd be curious to know how much trouble came of using the Motorcraft 2 bbl., if it is a 2100 or 2150. Should have some fits there with too rich due to power valve issues, depending on which carb used.
i have run an offy intake with a 390 holly 4 barrel and a mr gasket air filter for a year no problem.
There is a low profile air cleaner with a drop down base that might work.
The triangle shape air cleaner with all the holes in the top, that Edelbrock sells will clear ever thing just fine. Cheap too.
