Shiny is Good! => It's all about the Turbo... => Topic started by: johnbigman2011 on January 17, 2013, 05:52:44 PM
Has anyone had a turbo rebuilt before? If so, who would you recommend?
john we can actually send it to garret and have them rebuild it.
even if is not build by them they will rebuild it.
If the wheels are in good shape just order the bushings, thrust bearing and seals. It is mostly a simple hand tools job. Make sure to clock the compressor wheel and scribe the nut to put it all back in the same relative position and bob's yer uncle. google it, the parts are cheap and there are how to videos. I would recommend you make sure the parts are brand name stuff as the only word of caution.
OhSix'
I've been reading all kinds of info about rebuilding and buying the kits. What concerns me is balencing everything and the big fear of what happens when I do it wrong and send the parts throug the head.
that is a risk you can have even if you have some one do it for you..
Isn't the shaft brocken you yours? if so, it'll need to go to Garrett, It'll be pricey, and I think it needs a exh housing with a waste gate, might be cheaper to buy new right from Garrett with the correct seals...
ive had charlie at evergreen turbo do mine.... nice work at a good price... hes also a 2.3 guy....
Could you send me his contact info in a PM.
Post it if that's OK. I may need him too if my T3 needs freshening.
http://www.evergreenturbo.com/
Thanks for that Pinturbo75.
Ditto 8)
