Date: 07/13/2018 02:21 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
SVO SWAP
Date: 03/15/2018 03:12 am
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
Date: 09/17/2024 12:35 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Pinto drive train
Date: 06/29/2018 08:32 am
  • Online today: 1,459
  • Guests: 93
  • Total: 93
driveshaft lengths
Started by volksnut, June 30, 2008, 06:52:33 PM
volksnut
also I checked to see what it would cost to lengthen it....a whopping $150...WOW right
volksnut
yes if I measure it center to center to the u joints mine is 45 5/8th's also
My 1973 wagon, 2.0 engine, C-4 trans., 6-3/4" rear driveshaft measures 45-5/8" from the CENTER to CENTER of the U-joints.
While possibly not applicable to your situation when this shaft is used in a Pinto with a 2.3, T-5, 8" rear it works perfectly.
Tom
I have never done that swap but here is a little driveshaft info.
http://www.fordpinto.com/smf/index.php/topic,3008.msg23830.html#msg23830
I took an 8" rear and DS from a MII (V6-C4) in a bone yard. The DS was longer than a Pinto one. When I get the chance I will dig it out an grab a measerment for you. (it will give info on what the difference will be)
I would not have one modified, they are so easy to find in the correct length. Even if they take the wrong u-joints you can get cross-over ones to make it work.
Be careful, some shops or yards measure them differently; some do weld to weld, some do 'on-center' (like me), or the way you mentioned.
volksnut
I just installed the 2.3 with Pinto 4 speed trans in the daughters Mustang II....car had V6 before, well I know the shifter hole needs to be moved up a few inches, well it seems the driveshaft is too short too. The measurement I have from trans (seal flange) to rear yoke (where the u joint cup sits in) is 51 3/4"   Whats the Pinto shaft measure in at, if the same I'll look for one, I'm sure it costs more to lengthen mine?  Anyone know?
