Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 07/17/2018 09:22 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 12/31/2017 09:03 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
  • Online today: 1,972
  • Guests: 993
  • Total: 993
Rust loves to hide
Started by popbumper, June 26, 2008, 10:11:09 PM
Quote from: popbumper on June 27, 2008, 10:46:42 AM
....I have lined up a friend who is a welder and has a shop.....
I had so few friends until I bought my welder (car trailer, torches, lift,.....)
Geeze, Tigger, I knew somebody would "one-up" me  :lost:. Man, what a mess, nice rework on that. I am not sure how I am going to handle it, but I have lined up a friend who is a welder and has a shop - so that part of the puzzle is complete. I will keep everyone up to date on this.
Yours looks better than mine did.  I ended repacing almost the entire passenger side floor pan in my CW.  I cut some patch panels from a parts car I had and welded them in.  Mine was not the heater core.  So far one leak I found was from the pass side wiper pivot post.  It was a little loose and the gasket material was gone.  There is still a leak but I have not had time to find it.  I have not installed the interior yet because of this.  I want to make sure the car is water tight before I put everything back.  Good luck to you.  BTW, I have not had a chance to look for the parts yet but I will get to it over the weekend.
Costly - as in how much? And what turn time? Seriously - entertain me.
Yeah, I know - no sympathy from the East coast or Midwest guys. This is not a story of pity as much as one of discovery. You guys have the real rust work to do.  :hypno:
My penance comes in the form of rust that was carefully hidden between the floor mat /carpet on the passenger side, and the nice, unsuspecting sheet of undercoating beneath the car that was holding secrets beneath it.
In preparation for carpet replacement, I started the task of carpet removal. Picture "I" shows what goodness greeted my eyes when the carpet and pad were peeled back.  :wow:
Picture II shows after a treatment with a rinsing of phosphoric acid, and some dinking around with a screwdriver (holes are very easy to make this way).
Picture III shows both front and rear passenger pans, the rust is not exceedingly invasive (and fortunately does not involve the rocker seam, the trans tunnel (surface only), or the seat bolt weldments).
Yes, no pity for the man with the dry Texas car. Still, I should have known - nothing is what it seems until the layers are pulled back. The good news from today is that the carpet had the original tag on it, under the back seat; the company is out of business (no biggie), and I am going to send an unfaded sample out for matching.
Next week's plans include:
1) Cut the offensive pan out
2) Shape a new pan with sheet metal
3) Weld the new pan in
4) Treat everything on the floor with POR-15
5) Re-undercoat the underside
6) Fit the floor with dynamat (or something similar)
7) Order carpet
I am getting the interior done now, mechanical comes later.
