72 PINTO WAGON
Date: 09/23/2018 06:16 pm
Date: 03/06/2017 01:24 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 06/28/2019 09:14 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 03/17/2019 03:57 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
v8 springs
Date: 05/07/2017 04:46 pm
  • Online today: 1,972
  • Guests: 946
  • Total: 946
Rust loves to hide
Started by popbumper, June 26, 2008, 10:11:09 PM
I thought my '76 MPG wagon had 3.08 gears in it - but I may be wrong (I need to go check the paperwork again).
About the MPG models, these cars had different final drive ratios in addition to being detuned and stripped of unnecessary weight. As I recall, and an expert may be able to correct me, one rear end had 3:40 gears and one had 3:14 gears.
Chuck:
If you need any pointers, tips, whatever, let me know - be glad to help. My repairs were very successful!
I'm gonna have to steal some of your technique for my brother's bus, it came from colorado with holes in the floor, wheelwells, heater system and a hole about the size of a brick in the bottom of the left rear quarter. Still not finding much rust hiding in my Pinto, I've been under the carpet, in the trunk, carefully examined the firewall and cowl. I did find a few small bubbles on the edge of my trunklid though, and I'll get a pic of my 'rusty' battery tray up for you.
Yeah, that's what I am figuring so I'm gonna end up examining the cowl area very, very closely to make sure it is sealed. Once I fix the rust I don't want it to come back.
r4Pinto:
  Your water leak is probably where just about everyone else's is/was, at the cowl. Make sure you clean your vents out, and remove leaves/sticks/debris. Run a hose in thesr and take a look at your firewall on either the driver or passenger side, the leak will probably reveal itself.
My leak is an ugly nole hidden up under the driver's fender at the cowl; I still have to patch it, but my floors are great now. Good luck!
Wow! I am glad to find your post on rust repair for the floors. Although my floors are much, much worse than yours it has given me something to look at for when I do fix mine. I prolly aughtta pull the whole interior to do the fixing. Gotta find my water leak first though.
Exactly! Gee, I'm sure glad I have one ;D. Time for a turbo swap.... ;)
Reed
I am familiar with the Feather Duster and Dart Lite 1976-year-only fuel economy packages (my background is in Mopars and salnt sixes), and I figured the "MPG" option was something similar.
So really the package is just an overdrive manual tranny with tall rear gears combined with a tiny engine?   :-\  Not a good idea.  That might actually decrease MPG on anything that isn't flat or downhill....
While all might not apply to the Pinto most "MPG" type of cars from the '70's came with light weight components
(often aluminum), their smallest engines, radial tires, overdrive transmissions (often converted 4 speeds), and two point something rear end gears (can you spell "Bog").
  Plymouth sold an "MPG" style Duster called the "Feather Duster." It was by today's standards a very large car with a 3.7 liter 6 cylinder engine. Regardless, it had an EPA rating of 36 MPG!!!
Others will be able to fill you in better on the specifics to the MPG Pinto.
Tom
I think all cars had to have that emission stuff. As far as the 'MPG' side, the emissions controls were more likely to reduce fuel economy.
>EXPERTS< please jump in and correct me if I am wrong...
The 1970's were an interesting time. For those who did not experience it, the decade was the first in our Nation's history to recognize the environment (Earth Day comes to mind), and put pressure on industries and manufacturers to do something about carbon-based emissions of any kind. Like todays "hybrid" efforts, increases in fuel prices, gas rationing and stricter EPA mandates all forced automobile manufacturers to take a hard look at automotive emissions.
With public awareness heightened, manufacturers took on marketing campaigns that promoted the significance of these efforts, and specifically adapted "improvements" to the automobile drivetrains to accomplish better fuel effieciency, and fewer emissions, all under the umbrella of the "MPG" moniker - literally, "Miles Per Gallon".
MPG models were equipped with a fuel tank vapor collector (charcoal canister), a smog pump (that pumped air into the exhaust, helping unburned fuel to be oxidized), and the catalytic convertor, in addition to other vacuum-related enhancements that "tightened up" fuel and exhaust leakage issues.
Reed
WOW!  My pans look like crap compared to yours!  I am not going for looks though, I just want solid patches over the holes.
Your wagon is looking SHARP!
I have a question,  what is the significance of the "MPG"?  I have seen several people talk about it.  What option package was it?
Pintony:
  The car was quite clearly undercoated at one time, I would think at the factory. VIN data tells me it's a Canadian built car, but the DSO was Dallas, TX, so it never saw salt roads, which explains why it still has integrity. The rust was confined to floor pans (cowl leaks), and of course the cowl itself needs attention, since leaves sat in it for years and acted like a sponge holding water. Specifically:
1) Hood has only surface rust at the lock mech
2) Fenders are completely dry
3) Drivers door has a dime-sized hole at the front lower corner
4) Passenger door has a half-dollar sized hole at the front curve beneath the rubber seal
5) Rear hatch has a half-dollar sized hole at the window rubber seal (weird spot!)
6) Floors as stated
7) Quarters/doglegs/inner fenders are dry
  Some of the undercoating is starting to peel, so I will have to do another application when repaint time comes. I want this body to last another 30 years.
One more odd find - beneath the jute padding under the rear seats, I found a few of these "warning tags" folded up!! If you look carefully, there are check boxes for "engine", "electrical", and "fuel". I guess this is where the Pinto jokes come in....
OK, a little more work tonite; pulled the back "apart", removing the carpet, side panels, spare tire, etc. Discovered a few things:
1) Passenger wheel well was dented at the top, and the area behind the plastic panel was "sawed". What is interesting is that there is very POOR body work on the rear quarter, so it must have been hit, and they tried to access it from the inside. There was evidence of some broken glass in between the rear seat panel and body. The plastic panels are also crumbling somewhat.
2) Wheel well and all panels are solid w/o rust. Dog legs/quarters are solid. Tail pan is solid. Tail pan cover and plastic metal guides were removed, and all was vacuumed.
OK, two more shots showing the completed floor pans with BLACK POR-15 prior to sound deadening and recarpeting. Excuse the dirt/leaves; the car has a lot else to go through before I get the interior finished.
Just a comment regarding the POR-15.  It does NOT dry by venting solvents as regular paint does. It is actually moisture cured.  If you are going to dip your matting you should be using the whole can at one time. The more you expose the stuff to the air the more moisture it absorbs. Perhaps you might want to pour (no pun intended) the POR-15 over the matting on the floor. In effect you are painting the area and saturating at the same time.
I tend to use it in small amounts. What I will do is wait until the day/time has the least amount of humidity. I'll have a supply of vitamin sized containers and pour it to slightly overflowing (to completely remove the air) and quickly screw the cap on (air tight). I then label it and store it in the refrigerator.  It's not the cold that helps, but the fact that the refrigerator has very low humidity.  Even after all that I'll still find about 1/8" crusted on top when opened later.  However, that "opened later" as been as much as three years later and still 90% is usable.
  At over $50 a quart it's not something you want going bad.  I have use about 4 quarts on my Sunbeam Tiger. And, while I like the idea for inaccessible areas, I don't find it to be the "powder coat in a can" they advertise it as. To me "scuff tests" (like a dragging shoe) and being hit with heavy or sharp objects are two different things.
Tom
Reed
Quote from: popbumper on July 24, 2008, 01:32:17 PM
I mostly used a single layer, but added small second "patches" where there was more strength needed. A hint - when you lay down the fiberglass, don't lay it down and "paint" in the POR-15 as per the instructions - it is not very effective. DIP the mat (wad it up and put it in the can, and let the excess roll off as you remove it from the can); this soaks it really well, and then you can lay the mat down as one heavy, wet mass (is not as nasty as it sounds). With it thoroughly soaked, it also allows you to SHAPE the mat so that it can contour to the surface better. With more POR-15 interlaced in the fibers, the bond strength is enhanced. I can pound it firmly with my fist and I have no flex.
I totally agree, but I wish I knew this yesterday BEFORE I laid the fiberglass down and painted it.  D'OH!  I will add another layer today and that should be enough.  I ended up completely saturating the fiberglass mat with POR-15, but even then I had trouble getting it to lay down into the chanels.  I will fill any gaps or voids with more fiberglass and the putty.
Then it is time to strip out the interior panels and the dash for deep cleaning and repainting.   8)  I am going to add some wood accents along the way.  I am designing a wood handle grip for the e-brake that will slip over the all metal factory one.
Have fun, and wear those gloves, unless you like to have stained hands for two weeks!
Yes, the interior is gonna be a big job, but it will be beautiful when complete.
Reed
Chris-  how many layers of fiberglass did you use?  I used one, and it is stiff but still has flex.  I figure I need at least two more layers before the floor is stiff enough.
Sounds like me an you are doing the same thing!  as soon as I get the floor done i am pulling the rest of the interior and painting.  Fortuantely, I just need matte black, not a color.
Reed:
  Exactly! Take your time, clean it up well, follow the directions....this stuff is rock hard and really does a great job. As it stands right now, both of my pans are painted black - I need to shoot a pic of those and get them posted.
  Next, I need to finish the dash (repaint, add cluster piece, rework dash pad, fix steering column issues). Once this is done, I move to the back area, need to pull all the carpet and treat any issues, pull interior side panels and repaint, etc. I figure I can have the interior done before the rainy seaon (November and on). Of course, in the short term, hope to secure working space. This driveway stuff is for the birds - especially here in Texas, where daily highs have been hovering around 100 degrees, +/- 3 degrees. After 10 AM and before 7 PM are, well, "uncomfortable".
   Please post your results!!
Reed
Wow, those pictures look exactly like what I am doing to my Pinto right now.  I have gotten the first silver POR-15 coat laid down and now i need to go back and do the fiberglass and putty.   :laugh:
This is not the "final" pic (I still need to shoot those - tomorrow), but this IS the complete POR-15 treatment of the front passenger pan prior to final paint.
Yessir, thanks for asking, I will post pics tonite. Been slow on the trigger lately, have been looking for shop space (checking out this week), and the home A/C was out this weekend (fixed now), so have not been very active.
The floors turned out great, it's the cowl monster that gets attacked next.  :hypno:
Happy 4th everyone! Remember that we are a country of special freedoms, and remember our service men and women today as they sustain this freedom for us, >soapbox off<
This week has been a good week, I took off Wednesday and Thursday in addition to the Holiday. Having received a "trunk and floorpan restoration kit" from POR-15, I began the "daunting" task of reworking my rusty passenger front floor pan.
EDIT: For those just tuning in, I had posted some pretty ugly pics of my rust, and had planned to replace a floor pan. After much debate and consideration, I opted to repair the pan rather than replace it. For what it's worth, I think it turned out great.
On to our story. I have attached four pics of the process so far. I plan to have the whole process complete by tomorrow; the third coat of paint goes on tonite. I can say with confidence that the POR 15 product is excellent, and if directions are followed, is an outstanding alternative.
PIC 1 shows the holes in the floor exposed to the final patch point, being opened as far as possible and very thoroughly wire brushed. A good part of the damage (around the drain plugs) is protected from beneath by another intact welded crossmember, while the ho;es that go "to the ground: are obvious from the light beneath.
PIC 2 shows the alkaline (Marine clean) process for the POR 15 kit. You apply the material to all surfaces, scrub it in, then water wash it. It removes dirt and gunk.
PIC 3 shows the acid etch (Metal prep) step which is a spraying of dilute phosphioric acid, left to sit for 30 minutes and the washed and dried.
PIC 4 shows start of paint application. The holes are then covered with (what appears to be) fiberglass mat. I soaked the mat pieces briefly, laid them down over the holes, and the shaped the mat edges (precut before soaking) onto the solid floor pans.
More pics and process tonite after the third coat. As the car sits right this moment, the floor pan is rock solid, dare i say very strong. I also applied small patches to the floor underside to insure best integrity.
Quote from: popbumper on June 27, 2008, 10:46:42 AM
Geeze, Tigger, I knew somebody would "one-up" me  :lost:. Man, what a mess, nice rework on that. I am not sure how I am going to handle it, but I have lined up a friend who is a welder and has a shop - so that part of the puzzle is complete. I will keep everyone up to date on this.
Thanks Chris, I took most of the money I made on that blue parts car and bought me a nice welder.  The cutting and trimming of both panels was easy.  The welding is what I had trouble with.  I butt welded the rear pan and overlapped the front one.  Overlapping was easier for me but I am still a huge novice at welding.  It was a fun project for me but I am glad I only had to do one side.
...and there you have it. Nothing like a good woman. My woman is GREAT, but she wants nothing to do with the Pinto. Maybe I need to "reclassify" her..... ::)
Connie welded the roll bar in my first circle track car.
Wow, you just invented a new way to make friends, I like it! Take it one step further and promote dating - "Welding and women.com" - maybe not  :nocool:
