Date: 05/15/2022 11:36 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 07/04/2022 07:55 pm
Electrical
Date: 03/29/2017 11:37 am
Pinto for sale
Date: 04/19/2017 10:15 am
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 02/14/2019 06:27 pm
Date: 08/30/2018 12:59 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
  • Online today: 1,459
  • Guests: 84
  • Total: 84
2.3 Turbo in a '73 The Fun Starts... Again!
Started by Wittsend, June 22, 2008, 01:56:36 AM
Drive it? Oh, man I haven't thought that far ahead.  The time I drive is less critical than the fact that I do all I can and not wishing I had done something when the circumstances were better (as in while the car is apart).
The drive shaft when slid all the way in is a little over 1" away from the mounting points on the rear yoke. I basically mimic-ed it through the rearend travel and it seems just right.
I'll post some pics on the fan motor.  I think they are about $10 at the self serve yards. It's been 100+ degrees plus here in So.Cal. for days now. When your dirty, tired, hot and hungry snapping a photo isn't at the top of the priority list.
Tom
Great info for the heater motor!
I used the IHI on Connies car but I relocated the WGA to the engine side.
The C4 and the T-5 are roughly the same in length, but the 8" does push the driveshaft about an inch forward. I was not able to use the stock one a couple of times, but other times it was ok.
When do you think you will be driving it?
Well, after all the hassles I finally got the engine and trans aligned and the engine mounts welded in.  I'll tell you though, it was tough to "commit" knowing that it is basically a permanent issue. If there was a bolt hole relating to the engine or transmission (ANY of them), I slotted the holes..., just in case.
A couple of other things (hopefully pictures some day):
1.  The battery tray was rusted out. Since the battery has to be moved anyway, I hacked the whole section out and fabricated a new piece. It sits a lot lower than the original inner panel. This eliminates the outer exhaust bolt problem and created clearance for the wastegate actuator ( I have the Big IHI turbo with the wide placed wastegate actuator).
2. I found a great fix for the heater fan motor clearance!  I have a Sunbeam Tiger (Yea, yea, - Get Smart) and had replaced the heater motor with one from an MG.  It was about 2/3rd's the original size and could be called "stubby."  Slotting the two mounting holes was all it took to fit the Pinto with this item I snagged from the Tiger.  The cage is slightly smaller - and backwards, but reversing the polarity still has this thing pushing a lot of air.  I now have at least 1" clearance to the exhaust manifold (some might say the O2 mount).
3.  My '73, Auto with a 6-3/4" upgraded to a T-5 with a 8" rear end and the original driveshaft fits -PERFECTLY!
Happy (for the moment) Tom
