Date: 10/02/2017 02:16 pm
Date: 10/03/2018 02:00 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 11/29/2018 10:26 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 06/18/2018 03:47 pm
Date: 09/17/2024 12:35 pm
  • Online today: 624
  • Guests: 565
  • Total: 565
RADIATOR PROBLEM
Started by tim 1223, June 16, 2008, 06:32:17 PM
tim 1223
Thanks for the information. I really appreciate it. TIM
Tim1223.......It is the radiator cap....get a new 13 pounder and problem solved.
chrisf1219
hi i have a 77wagon 2.3 went i first had it and  after it warmed all the way up it would spill out antifreeze in a puddle on the ground. new radiator cap and a plastic overflow kit took care of the problem.get a correct new cap and kit this should help.  chris in ca.
tim 1223
Hello,
         I have a 1978 Mercury Bobcat with the 6 cylinder auto transmission in it.  The problem is that the radiator (upper) hose after driving enough for the motor to warm up swells. There is a lot of pressure built up in it.  If I relieve the pressure the hose goes back to the normal size.  I have blew two hoses already and had one hose come off of the radiator even though I had the clamp on really tight.  I cant figure out why this is happening!
On a side note I have replaced the water pump and the thermostat because they needed to be. The radiator was replaced as well.  Any help would be great.
Thanks Tim
