Date: 06/07/2021 08:14 pm
Date: 11/05/2016 09:03 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
1979 pinto
Date: 04/19/2018 02:02 am
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
  • Online today: 1,166
  • Guests: 542
  • Total: 542
2.0 plus 5-speed manual: whats needed?
Started by 73pinto, July 19, 2004, 03:35:36 PM
 Go to Pangra project and you will see the tabs I made for my T5 to 2.0L.
UltimatePinto
[colorHave a T-5 in my 72 Runabout. Will never go back to the 4 speed again. >:(
The top two holes are higher on a 2300, everything else matches up.
I did mine with a mig welder with a seperate aluminum spool gun with argon gas.
The other issues, the locating pins are smaller on the 2 liter so you have to make bushings to locate the bellhousing correctly. Also if you use the standard mechanical clutch cable, it will hit the crossmember. I modified mine to fit.
You will need a longer throw out bearing available from Esslinger or Walsh.
The stock mounting tranny bracket can be modified to fit.
I used a 75 automatic driveshaft that fit the tranny and my 8" rear fine.
Have some pics left of the install but am not sure if they are postable.=Red][/color]
HighHooder
Depending on your welding/fab skills, making an adapter really isn't all that hard... if you have the ability to weld, to read a tape measure and drill a hole accurately, you can adapt pretty much anything to anything.  Now, the input shaft might need to be shortened and you might need to have a new pilot bushing machined... oh, you will prolly need to fab yourself some nice custom tranny mounts too... will the fun never end???
heck, right now in my garage I have two adapters for the 2.0, one a "Pinto Beans" 2.0 to VW adapter, and one to adapt the 2.0 to a t-90 three speed, no, wait, that one sold. but all the same, theyt seem to be pretty adaptable motors
Proud owner of a 1972 Ford Exploder
73pinto
Due to the fact that gas is a $1.89 here and the syncro for 2nd gear is going out in my pinto, i'd like to put a 5spd in place of the 4 speed.  I've got a 5 speed out of an 80's 2.3 ranger.
Its my understanding that the bolt patterns for 2.3's and 2.0's are different.  Is there any modifications I could do to the bellhousing or anything I could get to make it bolt up?
Also, is the flywheel for a 2.3 the correct ballance for a 2.0?  Thanks.
-Harry
Stock 73 2.0/4spd 3:40 maximum slip, cd player, pop-out quarter glass.  Soon to be slight performance 2.0/5spd and much more...
