2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 09/26/2019 05:31 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 08/13/2018 02:46 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
cam pulley
Date: 05/30/2018 04:56 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 08/13/2021 10:39 am
  • Online today: 587
  • Guests: 236
  • Total: 236
Tach wiring question??
Started by uncleamin, May 18, 2008, 12:57:28 AM
It's cool. Thanks for taking the time to reply though!
uncleamin
Hey, I am using a sunpro as well. It's a bigger one with the white face and it actually is extremely bright. I'm not sure about changing the bulbs though...sorry.
Hey uncleamin, what tach brand are you using?
I just installed a SunPro Super Tach II on my 78 with a 2.3 and the light seems pretty dim compared to my SunPro gauges from the 80s. Would you happen to know if a brighter lamp can be swapped out?
illumination wire for the radio, glad to help ;D
uncleamin
I found the wire you were talking about, hooked it up, and it works perfectly. Thank you.
What is that wire anyway?
uncleamin
if you look at the wiring that goes to the radio, find the light blue/red stripe wire. should be a 2 pin connector.
uncleamin
Hey,
          I have it mounted and working.  I was just wondering for those of you who have installed after market tachs, where did you run the light wire? I'm just not sure where to hook the wire that controls the light. Anyone have a suggestion? Thanks.
