Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
Date: 07/13/2018 02:21 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 08/13/2018 02:46 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
  • Online today: 248
  • Guests: 182
  • Total: 182
magazine article on 2.3 build
Started by oldkayaker, May 17, 2008, 07:50:08 AM
I am surprised they did not go for a roller  cam?
The article said they milled the block 0.030" to get a zero deck height.  The head looked like a open chamber one and was milled 0.130" to get a 36cc combustion chamber.  The article did mention they used race gas.  It had a 0.040" over bore and stock stroke, assuming a gasket thickness of 0.040", guessing 5cc for the valve relief cuts in the flat top pistons, the compression ratio is around 13:1, if my math is correct.
COBRAII
Quote from: oldkayaker on May 17, 2008, 07:50:08 AM
The July issue of "Mustang Enthusiast" magazine has a nice article covering a build of a racing 2.3 engine.  It is a carbureted engine for mini-stock racing.  They milled for high compression, used 5.85" long rods, small crank journals, a 0.470" lift cam, and a very good build.  The head ports and valve size both look stock, but they did not say.  The intake is the oval port one (not EFI) with a 300cfm two barrel Holley.  The impressive (at least to me) is that they got 190 HP at 6,600 rpm and 173 ft.lb. at 4,800 rpm out of this.
When we  raced a ministock a lot  of guy's ran more carb than needed. Not surprised by the 300 cfm  but a little by the non efi manifold. How much did they mill off the head? quite a bit of power right there.
earthquake
