Date: 11/23/2017 05:44 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 02/18/2017 05:52 pm
Date: 10/31/2018 12:00 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 02/28/2018 09:33 am
1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 06/22/2017 07:19 am
  • Online today: 610
  • Guests: 349
  • Total: 349
rear window leaks- how do i fix it properly.
Started by crossy, May 14, 2008, 11:06:01 AM
Crossy the way I did the repair to my daughter's car was I got inside and had her go after it with garden hose to nail leak down. I would lift rubber seal were needed and add silicone.  Fred   :)
crossy
glass side and painted metal side of the rubber.?
ehh ehhh ehhh FIRE! FIRE!
Hi Crossy, I use the black silicone seems to work ok Fred    :)
crossy
gets my trunk floor wet and then under the seat. I can see it SLIGHTLY streaming inside the rear corners of  back glass. I know i could probably sqeeze some sort of sealer in under the rubber, but it prolly leaks in between the rubber and the window channel steel???
I can't even figure out how this ford molding inserts into the rubber if i wanted to get it out? I searched FAQS and i know this has to be an issue with many sedans .
thanx ,crossy
