Date: 04/27/2018 10:28 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 02/27/2017 10:10 pm
Date: 03/30/2021 12:29 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Date: 03/17/2019 03:57 am
1973 Pangra
Date: 01/06/2015 02:19 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 09/10/2018 10:41 pm
  • Online today: 186
  • Guests: 108
  • Total: 108
Question about bellhouseing bolt pattern on a 78 Pinto 2.3
Started by FuzzyFish, May 09, 2008, 11:27:42 AM
IMHO, just go with a T-5.  They are quite plentiful, and if you can find a five speed 4cyl fox Mustang, they are not as widely sought after as their V8 cousins.  Good luck with your project!
--Doug
 they are all the same as far as engine to bellhousing bolt pattern, but the ranger is a hydralic clutch. Im also thinking the trans to bellhousing pattern is different.
FuzzyFish
I've been trying to do some research into this. But I'm swapping a 2.3 out of a 78 Pinto, and looking at some of the "newer" transmissions.
Mainly I'm trying to find out if ford made any changes to the bellhousing bolt patterns through the years. Ideally I was planning on using a M5R1 from a ranger, but I rather not blow money just to find out ford made some minor change.
