Date: 02/18/2017 04:41 pm
Date: 06/19/2018 03:58 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
1979 pinto
Date: 04/19/2018 02:02 am
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 07/17/2018 09:22 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 05/22/2018 01:54 pm
  • Online today: 1,459
  • Guests: 786
  • Total: 786
How do you install window sweeps
Started by Pintaro, May 04, 2008, 11:07:22 PM
Hey Pintaro,
The sweeps are a trick-y If you need to remove them and NOT SCRATCH the paint then apply several coats of tape to protect the paint.
An Ice-Pick works good but I use a set of picks made by stanley tools that I bought at wally world... W-mart.
Some of the clips are installed in the rubber upside down so you need the hook-pick to get to the clips from the bottom.
You will also need a BRIGHT LIGHT to see down the cack of the sweeps to spot the clip. A set of those lights that look like sun glasses works GREAT and keeps your hands free.
  The clip is used in kind of a wedge and will need to be depressed to remove them with out damage to the door.
you will see a triangular tit sticking out of the hole push down on the tit of you can see it and up if the clip is installed upside down.
Hope this helps.
Pintaro
Ok does anyone know how to get the old window sweeps out and the new ones in?
        Pintaro
