Date: 10/26/2020 03:24 pm
Date: 02/25/2017 08:45 pm
V8 rear end
Date: 04/12/2018 10:57 am
Date: 02/18/2017 04:47 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Date: 11/14/2019 04:02 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 04/13/2017 04:56 am
Date: 02/10/2017 09:30 am
  • Online today: 506
  • Guests: 153
  • Total: 153
Pertronix insanity... Need help!
Started by 69GT, April 27, 2008, 08:37:26 PM
crossy
Is the Pertronix the same as the HOT SPARK unit I bought off of ebay. I assumed it was and that pertronix patent finally ran out.Good info to have for when i finally do this conversion. thanx , crossy
ehh ehhh ehhh FIRE! FIRE!
69GT
OK early on I had the feeling it was going to be a stupid simple thing that was causing my problem. So after a few days I approach the problem again with a fresh un-frustrated cause it's Friday and I am off work attitude and look really careful at the Pertronix. Ok. the reluctor managed to sit all the way down but maybe I was still missing something. So I took it all apart and noticed there is a spacer shim-plate in between the upper plate that the sensor eye is mounted on and the lower base plate that screws into the distributor that mounts the two posts that everything else mounts to. The middle plate just had the necessary holes but seemed to serve no other purpose so I removed it thus causing the eye to be more level with the reluctor  and re-assembled it, and viola no more misfire!!!! Still no explanation why three would work and one  (always the same one) would'nt but who cares. The Pinto got its first trip to the car wash in weeks and now drives like it never had a problem.  Thanks everyone for the help.
javascript:void(0);
fastcar
Hello 69GT,
Have you checked the tiny brass baided wire between the 2 advance plates are connected?
Maybe when you installed it you knocked it off??
P.S. if it is off? you will need a new plate assy. or some solder
Is the shaft worn and does it have excessive play?  Is the braided ground wire from the housing to the breaker plate present and connected?  I have ran a Pertronix module in my 67 Mustang since 93.  6 years ago I rebuilt the engine.  While the engine was out, I took the distributor apart to clean the varnish off the shaft.  I forgot to re-connect the ground wire and let me tell you it caused some wacky crap.  The car ran awful after it warmed up and had different symtoms every day.  It took me a while to figure out what I did.  I too pulled my hair out.  I ended up replacing the module because it overheated so badly without the ground being attached.  I just did not trust it anymore.  That is the only problem I have ever had with their modules and it was caused by my dumbass.  All I can say is go back to the basics.  Good luck to you!
69GT
Well today I tried both reluctors and adjusted the reluctor gap from .010 to .016 to .018 and .020. No difference. Rotate the reluctor change the plug that gets no spark. I e-mailed Pertronix and they say they will respond within 48 hours.
  The Pertronix unit I have on my 72 V-8 Maverick has worked flawlessly for the ten years it's been on the car. Maybe the whole batch of reluctors is defective. I tested the magnets and all 4 are accounted for. Though I cant tell if they are in the exact right position but pretty close.
Bipper: I checked. It's got the black rotor.
I am going out of my mind! I want my go-cart back! My friend thinks the only thing left is the distributor but I just don't see how based on what it does.
earthquake
Yep points,I got tired of the module going out and leaving me on the side of the road.No more module no more problems.I was looking at the pertonix unit because changing points in this thing is a real hassle.I have to remove the upper radiator hose,alternator,and float bowel just to get to the screws to remove the cap.
Brian that's right but in my case with my 79 rachero the module cost to much so I changed my dist. to point back in 84. When I get time I am going to pull that fuel pig eng. out and instal 94 2.3 rocker roller D port head + auto 4 spd. with point dist. and 6200 2v on a Morgan designed intake that took me 7 day's to make using chevy 350 header pipes and other metal's welded together. voom-voom.  :lol:
Quote from: earthquake on April 28, 2008, 09:12:19 AM
I was just getting ready to replace the points in my 80 wagon with one of those.I don't know about that now.I tried this once before but when it arrived I found it fit everything but my pinto so I had to return it,shortly after they came out with the pinto goodies for the kit.I would still like to go the pertronix route (changing points in my car is a major pain)so keep us posted on how it goes please.
  ??? 1980 with Points  ???
didn't points stop at 1974 and switch to electronic ignition  ???
earthquake
Have you checked the gap at all four positions? Perhaps the reluctors from Pertronix are eccentic (the complete lot) .  There are a bunch of guys on my Sunbeam Tiger side of life that use them. A few have has problems.  That said they (Pertronix) always seem to go out of their way to help them. I hope you get it sorted out.
Tom
Quote from: 69GT on April 27, 2008, 08:37:26 PM
       OK. I bought a Pertronix unit for my 2.0 72 Pinto. My friend (mechanic) installed it while doing some other unrelated work on the car. It shortly there after developed a misfire on the #4 cylinder. It was not getting any spark at all. So I did all the usual things new cap, rotor, wires, plugs, no difference! So then I check the gap between the reluctor and the Pertronix pick up. It's just right. Next I take the reluctor off rotate it and put it back on. Low and behold now number 4 is firing and number 2 is getting no spark! OK bad reluctor I say and order another one from Pertronix which they send free (Very nice). I run downstairs put it on with a big smile on my face fire it up and..... Friggin exact same problem! Misfires according to reluctor position. ANY I repeat ANY ideas on whats going on here?
-Aaron
Gee I really LOVE my points!!!!
I adjusted them in California after 2100 miles and again today. Took all of 1.5 minuets each time...
Bipper
I really don't know for sure if this would be a factor but you can't use the Bosh rotor when you do the Petronix conversion. It just doesn't fit in there right. If you are using the Bosh rotor, switch to the cheapo black rotor. If you are already using the black rotor, I don't have a clue as to what would be causing your problem. At least it's not expensive to try.
Bob
71 Sedan, stock
72 Pangra
73 Runabout, 2L turbo propane
69GT
-Aaron
