1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Racing seats
Date: 10/24/2019 09:41 pm
Date: 05/28/2017 03:20 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Date: 06/12/2018 08:18 pm
Date: 04/12/2017 08:15 am
Date: 11/23/2017 05:44 pm
Seeking parts
Date: 10/18/2020 10:35 am
  • Online today: 178
  • Guests: 108
  • Total: 108
Head Gasket--- Need holes cut?
Started by Scott Hamilton, April 14, 2008, 05:14:44 PM
Hey Scott,
Good thing you did the Pre-Start oil pressure...
How long did it take to find the problem???
Scott Hamilton
I did, but the cam spray bar was not spraying oil.. The head shop put the middle cam bearing in wrong blocking the oil from flowing to the spray bar..
Chucked an old distributer to spin up the oil pump while the engine was off to find this problem... !!!
I had to disassamble the engine again so they could fix their mistake,
Hey Scott,
I thought you had your engine together??
Scott Hamilton
Tony- it's the Gray Motorcraft w/ the red raised areas around the water ports- Purchased from Pegasus...
Thanks... I always wondered why some were totally blocked off on every gasket I have seen, now I know this was intended to be this way..
I guess I won't cut my own holes in the new gasket...
Hello Scott,
The little holes are to keep the "HOT SPOTS" of the head under control.
They work like a thermostat to prevent the water from running by too fast and not transfering the heat to the coolant.
Which gasket are you using the RED Victor gasket? Or the Blue FelPro Gasket?
Or The factory GREY gasket???
Scott Hamilton
Got a 2000cc head gasket and most of the cooling holes are 'not cut out' or will be blocked when installed...
Does that make sense? There are cooling holes in the head and the same in the block but the gasket (most gaskets for the 2000cc are this way) has them blocked...
My question- should I cut holes in the gasket for better cooling or is this restricted for a reason?
