Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 08/13/2021 10:39 am
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Date: 08/30/2021 03:20 pm
Date: 08/27/2018 11:11 am
  • Online today: 826
1977 Pinto- project in the works
Started by r4pinto, April 07, 2008, 07:54:57 PM
0 Members and 4 Guests are viewing this topic.
Didn't get the carb. While I was out working on my Grandma's car someone else set a better bid than I did. Oh well.
Congrats on getting her running!!!!  (Ok, I know I already said that on yahoo, but had to put it on here too!! LOL)
A carb swap is what I had to do on the Green Machine! Once I did the swap she ran fine!! Cleaned the old carb twice before the swap and never fixed the problem. I got my new carb off ebay too!!! Great place when it comes to getting some stuff kinda cheap!!  ;D Just got to be in the right place at the right time1!!!!
Congrats again. Now go out and drive!!!  :police: ;D
Thanks! I'm gonna put a different carb on the car to try to eliminate the initial bogging I am experience when I first start to rev the engine. Back when I bought the car in 2005 I was told by the previous owner they couldn't get the carb to act right. I rebuilt it but have never gotten the car to run right on it. Time to just get a different carb, especially since they are popping up on ebay.  :lol:
now thats good news r4 glad shes doing so well
Good news!!!!
After fooling with a bad miss at idle, with help from other Pinto members I tracked down a vacuum leak. The vacuum tree on the number 4 intake runner had a bad, bad rubber plug over the top, causing a MAJOR vacuum leak. I replaced the plug, as well as another small one and the car fired right up with no problem!
As the distributor in the car had a broken plug on it I swapped it out with a different one & got the timing and idle set.The car now fires up within a second of turning the key and at idle she runs so smooth, it's as if the car isn't running.
I have to be careful when I first get on the gas since it bogs down a bit at first but then I can get into it & she revs great!
Next I plan on fixing the oil leak, which I identified as the rear oil pan seal. Then I will be installing the radio and reassembling the interior. This car is really coming along & I couldn't be any happier about that. Next stop.... Mentor, Ohio.. Then Corry, PA!!!
Quote from: r4pinto on June 28, 2009, 11:51:04 AM
Just drove her around the block... Yes, you heard right. I changed the plugs and distributor & she fired right up. She has a heavy misfire but she still drives. Gonna work on fixing that, as well as the oil leak.
that is a definate step giant leap forward.
keep at it matt.
Oh you know it Becky... Only thing is I hateoverly long plug wires. Dunno at this point. We'll see.
You might as well replace the wires too. When I was getting Wildfire to run so we could go to Knott's the little metal cylinder in the plug wires that pops onto the spark plug disengaged fron the wire so I just replaced all the wires. I know it's more expense, and if I could afford to I'd send you the funds, but I think this is your next step.  ;D
Quote from: blupinto on June 28, 2009, 12:07:58 PM
The misfiring reminded me of a couple weeks ago. I took Avi (the Flying Avocado) to my best friend's place and when I tried to start her up to go home she actually backfired through the carb. It sounded like a gunshot. My friend looked out the window and her neighbor came out of his house and asked me about the noise. She hasn't done that since. I blame Fred! (just kidding Fred.  :lol:)
So do I lol.. It's gotta be a plug wire. They were way too long so I shortened them. I think I may have damaged them when I removed them to replace the plugs. Bad thing is I dunno how I can time the engine with it missing as bad as it is.
Don't be like me and, uh, overtorque the pan bolts. I still haven't forgiven myself.  :'(
Glad to hear that! I did go ahead & replace the external seals before putting it in the car so hopefully that will take care of that.
Good to see the progress.  On the tranny, if it has sat for at least 3 years you might have some small leak issues untill the seals get well lubricated just fom sitting.  My c3 is working very well and i am happy.
Forgot to update on the car...
Today I bolted on the exhaust & installed the alternator belt & tried to start the car. No go so I advanced the timing & she ran, but very fast idle. I disconnected the idle solenoid & it dropped back down. I got the solenoid on a carb I got from a buddy of mine but I will be taking it back off. Oh well, I tried anyways..
After fooling around with it I was able to get her going & set the timing. When I did that the car would not run with the vacuum advance hooked up. I am thinking the cam gear is off a few teeth or so. When I have the crank at TDC the distributor is at number one, but not sure of the cam. Gonna pull the timing cover to see. If the belt is off I'll reindex the cam & go from there.
I did get 5 quarts of tranny fluid in the car so once the car is running more consistently I will run through the gears & fill the tranny the rest of the way. I am a bit nervous since I don't know the condition of the tranny at all. I bought it off Pintony in 2006 but took him for his work it is good. We will see when I finish installing the fluid.
I remembered something about when I replaced the crank & all the related parts.. I didn't replace the rear oil pan seal. I bought a gasket set & did replace the front but the rear looked good so I left it alone. I am thinking I may have knocked it off when I reinstalled the oil pan. Least of my problems at the moment. Gotta get the car running first.
It was coming from the back of the engine. As quick as it started it stopped, so not too sure. Prolly will go over the bolts again just to make sure.
where was the leak? was the leak at the top of the pan? or somewhere else? if its the pan go over the bolts again and make sure they are torqued correctly and check it again.
I got the exhaust on the car & man does it sound awfull. I dunno if the patch job is making it sound like crap or if maybe the muffler was more junk than either Phil or I thought. I dunno but hopefully I can get her running right so I can find out. I did notice that when I had the right side in the air & tried to start the car she was leaking oil. It stopped as soon as I lowered the right side back down so I dunno what to make of it. One thing at a time.
Thanks Becky, Yeah I rebuilt the carb just a day before I started her up. We'll see what happens today.
Thanks Phil, Back in the 80's my mom got pulled over for a loud exhaust. She knew the state trooper that pulled her over & he told her "Anita, the muffler is supposed to be on the car. Not in the car".
I thought of her last nite since the muffler is sitting in the back. Got to shorten the pipe some more, then the muffler will fit. Thank goodness for sawzalls lol.
good   job getting life back in her.  now  if only  you had a muffler ...hummmm...............
:lol:
good thing we cut that one off.
keep up  the good work.
Sure wish I could go over there and help or hinder you! lol. I'm proud of you Matty! Harold II will be rarin' to go before you know it. I'm already suffering from Old Timer's Disease because I don't remember if you did any carb work, but maybe that's why she stalls when you press the accelerator. See? Wish I was there... ;)
Thanks Kim. At this moment she is sitting at the top of the driveway so I can work on her first thing in the morning. I have 4 quarts of tranny fluid in her & will put in 4 more after the car will run under her own power. I'm gonna see what I can find out about why the car will not run when I give her gas. It's almost as if she is suffering from fuel starvation, but I'm not too sure. I can't run her too long with no muffler on. That will be the first thing to get fixed tomorrow  ;D
Wooo Hoooo!!! Glad she finally ran!!! You are almost ready for the open road!!!! Can't wait to see some pics of Harrold II and some Ohio backgrounds!!  ;D
Congrats!!!!
Thanks!
I know it isn't the accelerator pump because when I  took the carb off the car I disassembled it to clean out any and all the rust that was in any crevis of the carb. One thing I did look at was the accelerator pump & it was very flexible. I'm gonna try to advance the timing a little to see if maybe that will help. One difference is on the car I installed the idle solenoid thing off of a carb I bought off a buddy of mine. Might try and disconnect that & see what happens.
Congrats on Harold II!
That may or may not be a dried out accelerator pump in the carb.
I'm amused that Harold II is a she.
In Sci-Fi Guy!, a webcomic that I'm working up, there are a cat-girl named Tom, a calico named Rover, and a tabby named Melvin. Melvin's clueless owner says things like "He had kittens."
Also there 's Pursia in my InterStellar OverDrive comic. Pursia is a female Junior on the planet she's from. So she's technically a Leonina Jr.
The time is 9:00pm in Ohio. At Approximately 8:58 Harold II was awakened from her 3 year long coma. While she is quite groggy and does not respond too well to the accelerator I am quite confident that come tomorrow she will have the get up and go of a newborn Pinto.
It came into my mind to make it sound like a patient in a hospital, especially since that is how I view my Harold II. She is not only my car, but my baby. Hopefully she likes her transplant, as well as the "open heart surgery" performed on her old, worn out engine. More to come tomorrow   ;D ;D :D
:fastcar: :tgif: Today, not only does TGIF stand for Thank God It's Friday, but also Thank God It's Fixed!!!
New Goal!!!
Get the car to fire up tomorrow or Thursday. Why the bump in the goal you ask? Because today I got the carb all cleaned out & adjusted. There isn't much to do to get her running, so I figure why not shoot for tomorrow or Thursday?.
Now, I did test my battery, and it is starting to show some age. The battery was replaced about a year before I bought the car and it wasn't that good of a battery to begin with. It just stands to reason that it is gonna go sooner, rather than later. Tomorrow I am gonna get some gas for her, as well as reinstall the driveshaft, tranny lines, and hopefully the starter. If that happens there is no reason why she won't start. As to how well she will run, I don't know. The goal is just to get her started.. Nothing more, nothing less.
Thanx Jim, I agree. I am just counting down the days till the weekend, when I can get the starter on the car. Once I do that nothing can stop me from firing her up!  :fastcar:
