Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 09/09/2018 03:22 pm
74 hood
Date: 07/03/2017 03:46 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 02/27/2017 10:10 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
  • Online today: 452
  • Guests: 381
  • Total: 381
Knott's - pedal swap?
Started by Wittsend, April 03, 2008, 01:42:52 PM
Tom, okee dokee Fred.   :accident:  hate that when that happens.  :)
Fred,
Well, with all that I won't have to send out a search party to find you. I'll see you there.
Tom
Hi Tom, it's kind of a stock junker, used to be red + wht. starting to turn to orange. 74 built in 8-73. Send out reg. last saturday but if car doesen't make it I will. I will be staying at lincoln ave R.V. park close to Knott's so that means you need my mobile # 928-916-1268. pinto is arizona AAL 2134. Motor home is arizona 991 DGX and I might be bringing my honda 73 sl125 arizona m/c WLM1. So hey how's that for some information. I will be staying there sat. night.  :accident: thet guy could use my 72 front bumper when I find out who he is I will give him a call.  :lol: :lol: :lol:
 Fred,
  Are you going to have your car in the show, or are you just attending as a spectator? If your in the show, describe your car and i'm sure I'll find you.  If not, I have your number and I'll call when I get there. As best I can tell my ETA will be 10:30-11:00 AM.
Tom
Quote from: Wittsend on April 04, 2008, 12:58:15 PM
Bill, thanks for hunting up the post (picture).  OK, my brake petal is like the one on the right in the picture. Obviously my petal is for a 4 speed so the pad area is smaller. The distance measures 4" for the pivot to pin centers (which is longer than the distance of the clutch pivot to pin distance).
Someone please correct me if I'm wrong, but I believe that confirms that I do have booster petals which is what Fred wants.
Fred, does this sound like a "done deal?"
By the way your question to Pintony regarding '72 petals in a 78 car. I can definately tell you the answer is NO! The mount is completely different. If that were the case I wouldn't be looking to swap in the first place. Someone else also confirmed this to me when I mentioned were I got the petals (from a 79-80 Pinto) and I was intending to use them on my '73 car.
Tom
This is ALL good info.
Hope someone is keeping track...
A 1 up for everyone!!!
Tom look's like bill is right. I pulled pedal's both from 72 man. and 78 automatic with boost. The meas. are 72 clutch 2" brake 1  13/16 " . On 78 4" and it mounts at top with about 3/8" bolt. Tunnel running for and aft 72 a little over 2" wide. 78 31/4" wide so it's a done deal . Give me a call so we know how to meet up. Fred 760-665-2316.  :)  My front room is starting to look like a pinto junkyard.
Tom
Quote from: 77turbopinto on April 03, 2008, 05:30:40 PM
....If the distance between the mount pivot and the push rod mount on the brake pedal is closer than the distance between the cable mount and the pivot on the clutch pedal its a manual brake pedal...
Quote from: Wittsend on April 03, 2008, 08:04:06 PM
....I measure 4" from the center of the brake pivot bolt to the center of brake rod pivot pin.
I measure 2-5/8" from the center of the clutch pivot bolt to the center to the center of the clutch cable pivot.....
Now you know which brake pedal you have.
http://www.fordpinto.com/smf/index.php/topic,7117.msg42786.html#msg42786
Quote from: Fred Morgan on April 03, 2008, 06:21:25 PM
We need more help because I measured both at 2 in.. Fred  :)
He said he had pedals out of a later car, that is what I gave the details for.
Quote from: Fred Morgan on April 03, 2008, 08:10:55 PM
Hi Pintony so this means I can still use 72 man. pedals in the 78 automatic with brake booster. Reply thanks Fred :)
Sorry Fred,
I do not have any post 73 Pintos so you will have to rely on other members knowledge for your 78 Pinto question.
Hi Tom, I will use calipers on it friday so I can get acurate measurement. Then I will get back with you later. I am going to check 78 to, we will get this figured out. Fred :accident: hate that when that happens.
Fred,
Tom
Pintony,
  Thanks, yes I knew that. I mentioned it so that no one would be expecting it if I am able to swing a trade.
Tom
Quote from: Wittsend on April 03, 2008, 01:42:52 PM
Hi,
  While I didn't get the actual firewall to steering column structure they mount to, I did get most everything associated with mine when I removed them.
Thanks, Tom
Hello Tom,
You do not need the structure all you need is the pedals and rod that is on the clutch.
An easy way to tell: If the distance between the mount pivot and the push rod mount on the brake pedal is closer than the distance between the cable mount and the pivot on the clutch pedal its a manual brake pedal.
Fred,
  I'm not sure if the car had a booster or not.  It was an ESS optioned car. Maybe the booster is standard in that package???  While I can't say for sure, on most cars the booster issue is the actuator rod, not the pedals. I can't confirm that for the Pinto though.
  Hopefully this will work out to each of our mutual interest.  I can measure the rotating pin to brake hole distance (or any other practical measurement) if that will help.
Tom
Guys give me information. I have a 78 hatch with automatic I am going to instal manual shift and it does have brake booster. I am going to Knott's. I have a 72 hatch with man. pedals. So if I get time to pull, can I use youre 79  pedals. Thanks Fred reply. :)
Hi,
  Being relatively new here I haven't amassed a significant amount of Pinto parts.  That said, I incorrectly purchased a set of 1979 or 1980 clutch/brake pedals for my 1973 Pinto.   I'm just curious if anyone going to Knott's would have, and be willing to swap my late model pedals (they're the ones with the brake pedal pad at an angle) for a set (both clutch and brake) that will fit an early model, 1973 Pinto.  While I didn't get the actual firewall to steering column structure they mount to, I did get most everything associated with mine when I removed them.
Thanks, Tom
You also need to know if the brake pedal is for a car with power brakes.
I have never had an issue with the underdash brackets when I swapping out pedals. All the ones I have worked with had all the holes to do the swap including power or manual brakes.
Hi,
Thanks, Tom
