Date: 11/23/2017 05:44 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 08/27/2018 11:11 am
Date: 08/22/2018 09:23 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 02/28/2018 09:37 am
Date: 04/20/2017 10:10 am
Date: 08/22/2017 09:21 pm
  • Online today: 1,431
  • Guests: 477
  • Total: 477
Project Cat
Started by phils toys, April 01, 2008, 12:08:20 PM
I would assume that the rings are shot due to age and so much force being needed to turn the engine over. I would play it safe and change them out now while everything is accessible instead of later when you'll have to pull the entire thing apart again.
Here is the latest up date
Donor passenger  floor removed from other car. now i have to do minor repair and trimming to get it in Cat.
Finally got the motor to turn over pistons broke free after soaking in oil for about 2 weeks and the still did not budge, and having talked to a few mechanics about braking them free  the common answer was use tranny fluid. I cleaned out the oil  and put enough tranny fluid in to cover the  top of the pistons and  went to get the breaker bar and socket again to Try just for kicks and they moved a bit. I worked them back and forth a few times and cleaned out the fluid and replaced   moved them a few more times and they moved about a half inch  worked them some more   and they would only move the half inch or so  I got impatient and got the 4 foot cheater bar out and  broke the breaker bar (it had been previously repaired)  I got a different breaker bar out and SUCESS   Changed the fluid again and worked the pistons  around several  times with breaker bar then changed to ratchet and finally able to move with my hands.The only problem is how bad are the rings at this point.....   ???
Also will need a cam shaft and followers  severely worn and a lifter (it is broke)
Phils toys
Lookin good Phil. Nice catch.
Kat undergoing surgery for the new face lift
Nice weather on Sat. The boys and i went to get parts.
Picture 1 The boys getting the bumper, while i tried to get the replacement floor. They were more sucessfull than i was.
bobscat
Wow, was that thing setting in a field or something?  The body doesn't look too bad at all, but man, those floor pans could use some help.  It looks as though you have a pretty nice car to start with, looks pretty complete.
Quote from: 77turbopinto on April 01, 2008, 12:40:25 PM
Kool, it looks like you have a good car to work with.
BTW: In the second photo (the engine one) I can see you still have the plug in the fenderwell (top front part of the photo). That is only the second one I have ever seen. I found one and put it my V8 car that Norm now has.
Thanks  Bill, if you need more of those pugs i have 2 more as the doner  car for the pass floor has them in it.
Here is a picture of the non existing floors
more pictures
Well here are some pictures of my newest car. It may be more than i can handle but time will tell. It has 166000 pus miles on engine  and it was tore down over 10 years ago with a blown head gasket. Floors are rusted through just not sure how bad untill i lift carpet.body wise the drivers fender has a hole and the hatch has a small hole other wise it seems prety good. but realy needs paint.
