Great Cruise wagon
Date: 12/17/2016 03:39 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 08/01/2018 01:17 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 09/10/2018 10:41 pm
Brake rotors
Date: 03/24/2017 09:02 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
2 liter blocks and heads
Date: 03/28/2018 09:58 am
  • Guests: 2292
  • Total: 2292
Modify your PCV System!
Started by mikerich1972, March 29, 2008, 06:13:20 PM
earthquake
Hey Mike
   The boat is using an Evac system.This works the opposite of yours.The Evac only works at high RPM,above 3500.Not a streetable system.
mikerich1972
 FYI: I checked out a mini hydroplane racer this past August. Guess what!! It's powered by a 2.3 L Pinto engine. AND, the engine is completely air (and water) tight! They are running the PCV system to the exhaust header, which provides adequate vacuum in the application!!
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
I love having the sealed cap on my motor, it really does make a difference in low end power (most noticeable on take off), at least on the 2.3. If you don't  believe me, try running your motor like this for about a month, then go back to using the stock cap and you will feel the change.
I noticed a DROP in gas mileage, so I don't regularly use it. However, I keep a sealed cap in my trunk with all of my emergency supplies so I can throw it on if I want to do some cookies in a parking lot this winter (and it does help :)).
mikerich1972
 Anyone else do this mod and have stories to share?
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
 Exactly as DAVE1987 said, on our Pintos, it is simply an oil filler cap conversion...
The long story is, however, that you should do all you can to seal up the engine in addition to changing the cap. For example, the oil mist eliminator, on the side of the block, may require removal and sealing. The rubber seals tend to be a bit sloppy after years of thermal cycles.
2003 Ford Motorhome
2018 Ford Focus
Reed
I am still unfamiliar with my 200cc.  I need to investigate further I guess.
should be under the intake manifold plugged into the vapor canistor (?) that is stuck into the block
Reed
Uh,I just looked and my 71 200cc motor doesn't even have a PCV valve.  No dice for me on this one....
Basicly it's just an oil cap conversion.
Instead of using the "vented" one that leads back to the air cleaning through a hose, you are using a sealed cap.
I pulled the cap I was using off an old Chevy 350 motor in the salvage yard (which had a good seal). It is the cap on the valve cover.
Reed
I am very interested in trying this, but still unclear as to how it is done.  How about a step-by-step walkthrough (with pictures?) of how you do this.  I have read the instructions several times, but I still don't get exactly what needs to be done.   ???
mikerich1972
 Any more news from other Pinto drivers on this?
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
 Anyone else besides Earthquake willing to try this?
Just curious since I haven't seen any more comments/complaints for a while!!!
2003 Ford Motorhome
2018 Ford Focus
earthquake
My air filter wont allow this so I'm using a small breather filter that slips over the end of the hose.All this is temp till I get everything figured out anyways.
mikerich1972
  One way to reduce the dirt infiltration into the vacuum system would be to run the "bleed" hose end into the filtered air. In the case of an older Pinto, this could be done rather easily by running a longer tube into the air filter can, inside of the filter.
  Just a thought...
2003 Ford Motorhome
2018 Ford Focus
earthquake
Well it's been about a month now and heres what I have found out about this little trick and the results I've gotten so far. with all the tuning changes my fuel mileage has gone from about 16 to 17 in town to about 23,for a 6 to 7 mpg increase,very nice.And I think there is more to be had but tuning with this system can be a challenge.My next step will be a jet change,leaner and a power valve change,it seems to be running a little rich at this time.As for what I found out about this little trick,this is nothing new.Dirt trackers around here have been doing this for years free HP.But if you live in a dusty area unless you allow a small amount of air into the block it WILL draw air in past the seals,with the air comes DIRT.At idle my engine starts to make a sound like a belt slipping or a water pump bearing going out.As it turns out what I'm hearing is the air being drawn in through the aux shaft seal.Now for the fix,And Mike this should fix the prob with your Chevy.Pills are the answer.With my set up I have a bolt threaded into the hose on the cap to block it off,Tacky I know but it was an experiment.Next I got a couple more bolts and cut them into .75 in sections,then using wire drill bits drilled holes through the sections giving me the pills I needed.From there i just start with the smallest pill and work up till the problem stops.From there you just install a filter on the line you have the pill on to stop dirt from entering.The drawback to this is the air entering the block through the pill makes a little noise,very little but the filter seems to muffle it.More on this later as we are looking at installing an crankcase evac system for hi rpm as the other does nothing there.
     Doc.
earthquake
I have been using denatured alcohol for years as a fuel system cleaner and octane booster,about 6 to 8 oz to the tank.As for fuel blends,If I'm seeing improvements with winter blends It should get better with the less volital burning summer blends.
So far so good. Engine is still running smooth and I'm actually seeing the MPG increase now. I filled my tank to the brim two days ago. With my regular driving around town, errands and work, it usually drops slightly below the full line. So far it hasn't budged! I will post again when I hit 3/4 tank.
Now while on the topic of improving gas mileage, does this trick actually work?
http://www.mdwholesale.com/Improving_gas_mileage.html
You also need to consider that the gas formulas change for the summer right about now; this alone might have an effect on your milage.
earthquake
Well at this point I have noticed an mpg increase..Yesterday I had to make a trip to Fall city was running late and did not have time to gas up.I knew I had enough to get to where I was going but would have to re fuel before going home.I was shocked to see that my fuel gauge had moved very little after getting to my destination.Well I figured I'd take a chance and just head home.I could not believe I still had fuel after getting back,and still was able to do some running around town after that.I figure I went 40 miles on 15 to 20 miles worth of fuel,I'm one happy camper.My speedo is off by 10 mph so I cant get exact,Anyone know a formula for calculating with speedo error.By the way,Thanks for the idea Mike,I'll keep you posted.
It seems, so far, that my MPG has dropped a bit. I do not know why or if it has anything to do with the tuning of the car. Vacuum pressure has not decreased or increased on my gauge (still getting 17-19) and I have not yet adjusted idle mixture or curb idle.
mikerich1972
Sounds like you are definitely on the right track, Dave!
At idle, you probably won't be able to remove the cap. That's a good thing, and why this actually helps you out!
Now, keep a close eye on the MPG's, I would love to see your results posted here.
2003 Ford Motorhome
2018 Ford Focus
I went out to the pick-n-pull today and pulled some caps off some engines. I found one with a good seal and put it on. So far everything is okay.
Before with the stock cap I could pull the cap off without a problem, now I can't even get a good grip on it from so much vacuum. Good or bad?
I have noticed an increase in driveability though. I shift into third at 30mph instead of 25 and the engine definitely runs at a lower RPM when driving in town at 35.
I cannot tell if it has increase my MPG though, since I still need to readjust the idle mixture and the curb idle. I will update in a week to let you all know though.
This is on my 78 Sedan without the EGR valve and tube, running off a 4spd tranny and the 2.3l engine
earthquake
My over all low end seems to have improved a little.I can now use 5th gear at 35 instead of 40 to 45,and at that speed it seems to pull harder at 35 when you mash it than it did at 40 before.Most would call my car cantankerous on the street as it acts like a 2 stroke,No pull than tire rubber.This seems to have smoothed that out.It is not nearly as sudden as before.
what do you mean by a little more low end?
earthquake
I set it up on my car today,Noticed a marked improvement in overall drivability,and it seems to have a little more low end as well.We will see how it goes from here.
I still plan to try it out, even if I do not understand it. I just need to get to a pick-n-pull to get a sealed cap. :)
mikerich1972
Quote from: dave1987 on April 01, 2008, 02:21:02 AM
So are you saying that by just capping off the vented oil cap with a sealing one will improve horsepower and MPG??
I do not see any logic in this.
Okay, so simply don't do it! Nothing ventured, nothing gained...
No loss for me.
2003 Ford Motorhome
2018 Ford Focus
apintonut
how about a diagram to explain this better?
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
mikerich1972
Quote from: dave1987 on March 31, 2008, 08:17:07 PM
How about the hose where the PCV valve connects to to the block?
Definitely leave that in place! That is your vacuum source from the intake manifold to the block (crankcase).
2003 Ford Motorhome
2018 Ford Focus
