  • Online today: 110
  • Guests: 102
  • Total: 102
1976 Wagon with 308.000 miles!
Started by mikerich1972, March 24, 2008, 07:47:13 PM
Quote from: mikerich1972 on April 01, 2008, 12:35:31 PM
What I'm referring to when I mentioned water vapor problems in the winter is this: Lower block temperatures (when parked) will condense more water into the oil than most any other time of year. This is particularly true if you make short trips, as in-town driving tends to be. With short trips, the water never has time to be vaporized and purged.
As far as "tampering with an emission control system".  Show me a federal, state, or any other regulation that this simple procedure violates! The EPA is concerned with ONE thing in a PCV system: that it purges the hot oil, blow-by, and combustion gases from the crankcase into the engine to be re-burned in the combustion process. I am not changing that in any way!!!!
Now, to address my feelings on the intake temperature reduction:  In the 2.3L Ford engine, we are looking at about 122 CFM at full throttle (stock, unmodified 2.3 liter engine, running at 5,000 RPM). Considering the amount of purge air pulled through the stock PCV (I would guess somewhere around <8 CFM), I believe the change in actual inlet air temperature is negligible. Certainly not enough to create a chilling affect required to increase the density of inlet air.
As for the concern of "sealing up" the crankcase:   This is simply NOt what I'm suggesting! The crankcase is still ventilated... it is just not ventilated as thoroughly as it was. We are now creating a negative pressure inside the block, instead of simply pulling air through the block.
I hope this clears up some of your questions and concerns!
Mike, just wanted to answer your questions reguarding " tampering with an emmision controll system. Read below.
3704.16 Prohibiting tampering with motor vehicle emission control systems.
(A) As used in sections 3704.16 to 3704.162 of the Revised Code:
(1) "Tamper with" means to remove permanently, bypass, defeat, or render inoperative, in whole or part, any emission control system that is installed on or in a motor vehicle.
(2) "Motor vehicle" has the same meaning as in section 4501.01 of the Revised Code.
(3) "Emission control system" means any system designated by the United States environmental protection agency as an emission control system under Title II of the "Clean Air Act Amendments." "Emission control system" includes any device or element of design of the system.
(4) "Clean Air Act Amendments" has the same meaning as in section 3704.14 of the Revised Code.
(5) Notwithstanding section 3704.01 of the Revised Code, "person" has the same meaning as in section 1.59 of the Revised Code.
(B) No person shall do any of the following:
(1) Sell, offer for sale, possess for sale, advertise, manufacture, install, or use any part or component intended for use with or as part of any motor vehicle when the primary effect is to bypass, defeat, or render inoperative, in whole or part, the emission control system;
(2) Introduce a leaded fuel into a motor vehicle that is designed, manufactured, or certified by the United States environmental protection agency to use only unleaded fuels;
(3) Tamper with any emission control system installed on or in a motor vehicle prior to its sale and delivery to the ultimate purchaser;
(4) Violate any rule or order the director of environmental protection adopts or issues under section 3704.161 of the Revised Code;
(5) Refuse to permit the director or his designee to inspect any motor vehicle or documents as provided in division (A) of section 3704.161 of the Revised Code.
The sale, offering for sale, possession for sale, advertisement, manufacture, installation, and use of a part or component in violation of division (B)(1) of this section all constitute separate offenses.
(C) No person shall knowingly do any of the following:
(1) Operate a motor vehicle that has been tampered with if the motor vehicle or motor vehicle engine has been certified by the United States environmental protection agency as meeting federal or California emission control standards;
(2) Sell, lease, rent, or offer to sell, lease, or rent, or transfer or offer to transfer title or a right to possession of a motor vehicle that has been tampered with;
(3) Tamper with any emission control system installed on or in a motor vehicle after sale, lease, or rental and delivery of the vehicle to the ultimate purchaser, lessee, or renter.
The sale, lease, rental, and offer to sell, lease, or rent, and other transfer or offer to transfer of title or a right to possession of a motor vehicle in violation of division (C)(2) of this section all constitute separate offenses.
(D) Division (C)(2) of this section does not apply to either of the following:
(1) Any person who sells, leases, rents, or offers to sell, lease, or rent, or transfers or offers to transfer title or a right to possession of a motor vehicle that has been tampered with if the person is acting as a motor vehicle auction owner, a special auctioneer, or a salvage motor vehicle auction and if the person holds a current and appropriate license to engage in those activities issued under Chapter 4517., 4707., or 4738. of the Revised Code;
(2) The sale, lease, rental, or offer to sell, lease, or rent, or transfer or offer to transfer title or right to possession of a motor vehicle that has been tampered with if the vehicle is titled with a salvage certificate of title issued under section 4505.11 of the Revised Code.
(E) Notwithstanding divisions (B)(1) and (3) and (C)(3) of this section, it is not a violation of those divisions if either of the following conditions is met:
(1) The action is taken for the purpose of repair or replacement of the emission control system or is a necessary and temporary procedure to repair or replace any other item on the motor vehicle and the action results in the system's compliance with the "Clean Air Act Amendments";
(2) The action is for the purpose of converting a motor vehicle to use a clean alternative fuel, as defined in Title II of the "Clean Air Act Amendments," the motor vehicle complies with the applicable standard adopted under Section 202 of that act when operating on the fuel, an emission control system is installed or replaced upon completion of the conversion, and the action results in the system's compliance with that act when the motor vehicle operates on the fuel for which it originally was designed.
Effective Date: 09-27-1993
Quote from: lencost on April 01, 2008, 02:01:23 PM
This is an idea that a member decided to share in this forum. The cost of trying this is zero if you jest temporarily clamp off the inlet side of the PVC system. Wen I get my Pinto back on the road I plan on trying this, and then I will post my experience.
Where did I say he should not have posted this?
Where did I post that people should not try it? (as long as they are aware that there are risks)
I am all for trying new (or old) ideas, but It just seems like he is trying harder to prove that others are wrong than anything else.
BTW: Would it still be "Zero Cost" if you had to repair something?
lencost
Quote from: 77turbopinto on April 01, 2008, 12:58:55 PM
So let me see if I have this correct.....
You post your idea with it's potential benefits (and a few known drawbacks) but provide no scientific documention, certified tests or studies showing why it has the effects that you claim, THEN if someone else posts concerns or opinions you require them to provide documentation, and it they don't, they are wrong.
OK, got it.
This is an idea that a member decided to share in this forum. The cost of trying this is zero if you jest temporarily clamp off the inlet side of the PCV system. Wen I get my Pinto back on the road I plan on trying this, and then I will post my experience.
1975 Wagon 8" C4 2.8 V6
You post your idea with it's potential benefits (and a few known drawbacks) but provide no scientific documention, certified tests or studies showing why it has the effects that you claim, THEN if someone else posts concerns or opinions you require THEM to provide documentation, and if they don't, they are wrong.
OK, got it.
BTW: In round numbers:
114 CFM @ 80* + 8 CFM @ 200* = 122 CFM @ 87.9*
mikerich1972
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
Quote from: Farmboy on April 01, 2008, 09:16:30 AM
  77Turbopinto, you never spent a winter in western Wa, its very wet here ;D
i think he's talking about relative humidity. in winter the air is dryer
Farmboy
  I do what the voices in my Pinto tell me to do
74 Pinto Wagon
71 Runabout (parts car)
Quote from: mikerich1972 on April 01, 2008, 12:05:47 AM
......In fact, the oil stays "drier" in the winter (without pulling in all the water vapor from outside)......
.......The important thing to remember here is that the gases are still being drawn into the intake manifold, NOT vented into the atmosphere as unburned hydrocarbons. Therefore, the EPA would not have a problem with our doing this........
A) Aren't winters 'dryer' than other seasons because cold air can't hold the mosture that warm air can?
B) It is still tampering with an emission control......
I still think that the biggest benifet is colder air intake temp.s.
mikerich1972
Okay, I'm back to answer some of these concerns!
At idle, my 308k mile 2.3L runs at about -22" HG (mercury). In a perfect world, I would be able to pull a -20" vacuum on the crank at idle. In the real world, with leaks, blow-by, etc, it actually runs at -4 to -5". So, yes the blow-by IS a factor in this. But it is negligible.
In my mind before I applied this to my car, this vacuum would make such a small difference in the internal rotational drag that it would be immeasurable. This is simply NOT the case. It is real, measurable, and does not do any harm to the engine.
In fact, the oil stays "drier" in the winter (without pulling in all the water vapor from outside). The oil, however, become more contaminated with combustion by-products faster... meaning change your oil at regular intervals!
The crankcase blow-by is still being removed from the engine block; just not as quickly. It is more like a teapot with a small opening in the lid on a hot stove, instead of an open pan with a fan blowing across it (figuratively speaking). The byproducts are still being removed from the enclosed space, just not as quickly as with more purge air. The important thing to remember here is that the gases are still being drawn into the intake manifold, NOT vented into the atmosphere as unburned hydrocarbons. Therefore, the EPA would not have a problem with our doing this.
In fact (and I have no data to prove this!) I would be willing to state that an engine with this in place would easily pass emissions testing. We simply have not created a path for this nasty stuff to purge un-burned into the atmosphere, we have just reduced the air flow; not altered its path!
2003 Ford Motorhome
2018 Ford Focus
OK, well, for obvious reasons this would not be a good idea to be used on a forced induction car.
Quote from: turbopinto72 on March 31, 2008, 11:40:16 PM
Ok, I re read his post in the other thread. If he is saying " use an external pump to evacuate the crank case " I understand that. There are a lot of racers that use a pump to " zoop" the crank case dry ( so to speak ). There is another way to do it by using the exhaust system to " pull " the vapors out of the crank case.
YES except Mike's idea is using a tube to the intake manifold to evacuate.
At least that is how I understand it.??
Quote from: turbopinto72 on March 31, 2008, 11:31:15 PM
Ummm, huh ??.
You still need to evacuate the crankcase. I hear Mike saying he wants to " seal it" is that not the case?
evacuate? Isnt that what a vacuum is? vacant space??
Again I'm not saying that it is good or possible or bad, iduno????
I'm confused myself???
Ummm, huh ??.
Quote from: turbopinto72 on March 31, 2008, 08:55:02 PM
I'm sorry but I am having a hard time with this. The crank case needs to breath or there will be so much crank case pressure built up it will blow out the dip stick. By sealing it off you will not have an effective " air pump" I can see tons of HP loss with this not to mention damage to parts. ??????
I'm not going to pretend that I understand this but...
Mike is trying to say that the crank case is sealed EXCEPT for the vacuum applied to it by the intake manifold. If an absolute vacuum is applied then there is no pressure.
If you put a wind-up airplane in a vacuum tube and then let it go the propeller would spin really fast as there is no air to slow it down but no air to pull the plane forward either. So having a partial vacuum applied would produce HP.
as there are 2 pistons moving down and 2 pistons moving up at the same time in a 2.0 or 2.3 engine. and the Vacuum is NOT "absolute" if the c.c. needed a little air back for some reason it could take it as there is NO checkvalve to stop air going in either direction.
Right. And the PVC valve/ crankcase vent system also keeps the certain % of blow-by i.e. gas from collecting in the oil system and contaminating it
 Well, in an ideal world there would be no ring blow by. So, the crack pressure ideally shouldn't change. But within the crank case you have pistons offsetting the air, I would think in a push/pull fashion. The spinning crank would create "wind like" a fan. But even that possibly is simply replacing like air in occupied space. So, I would guess it is the difference in temperature (crank case to atmosphere) that causes the most air movement related to the venting the crank case.
In years of old cars simply had a breather tube venting to the air I don't recall major pressure issues with good rings and valves.  The PCV was just a way of burning hydrocarbons given off by heated oil. It created a vacuum and force the vapors into the intake.
Tom
If you think about it, every 4th rotation of a given piston there is a " vent" via the exhaust valve opening. But, in a closed crank case there is no " vent" so , where does the compressed air go to ?
 The thing I'm wondering about is if a piston is moving up and another down, doesn't this offset each other in regards to occupied air space?
  So, when a vacuum is created (as with this modification) and a piston needs to occupy space (moving upward), doesn't that vacuum impede the upward movement of the piston in the same way atmospheric pressure impeded downward piston movement without the modification?
I'm not up on Physics, but maybe things move easier in a vacuum and the same trade-off of piston up/down movement mentioned above becomes more efficient?
I have seen drag cars apply this negative pressure principle, but they siphon a vacuum off headers. I guess at full throttle the header siphon creates more vacuum than dual four barrels do on the intake side.
Tom
Quote from: mikerich1972 on March 30, 2008, 07:47:51 PM
Well, just cap, or change out, the oil fill cap. What you want to do is create a vacuum-tight crankcase. Be careful to watch your oil seals, though!
Im sorry but I am having a hard time with this. The crank case needs to breath or there will be so much crank case pressure built up it will blow out the dip stick. By sealing it off you will not have an effective " air pump" I can see tons of HP loss with this not to mention damage to parts. ??????
mikerich1972
For a lot of you folks who are wondering why I would be willing to share this idea on a small website forum, I'll be happy to answer that.
I presented this idea to many car-guy friends, most of whom looked at me like I was crazy! I also contacted the local city maintenance department about trying this on some of their vehicles. I got the same reaction!! What's the problem here? Unbelief...  Most of us believe that if something sounds too good to be true, it usually is.
This idea is NOT new! Drag racers have been doing this for years to sneak out a few more HP's.This is also why I can't patent and market the idea. But, what I CAN do is get the word out! All I'm asking is that you try it. If you don't like the outcome, or if it flat doesn't increase your gas mileage, then reverse the mods and we'll all move on. Nothing really lost!
However, if it DOES work for you: pass on the information!!  (It's here on the site for free) All I'm asking is that you let me know how it's working for you. What increases have you seen?
I worked as a Mechanical Engineer at a nuclear fuels production plant for 14 years, responsible for the HVAC, Containment, and Air Sampling systems, among other equipment. I spent about 26 years working with all types of HVAC systems. Because of this experience I too, was very skeptical of the seemingly minuscule gains available with such a simple modification. That's why I had to prove it to myself before I could put this out to the public!
I'm not in it for profit. I just want to beat the imported oil thing as much as I can, any way I can.
Thanks for listening!
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
Quote from: dave1987 on March 30, 2008, 04:22:14 PM
Back on topic to the original post...
Are we talking about capping off the crankcase vent valve and the oil filling cap, thus making the engine a closed "circuit" with no external ventilation?
2003 Ford Motorhome
2018 Ford Focus
Quote from: mikerich1972 on March 30, 2008, 07:28:47 PM
Sorry bill, no direspect intended....
None taken.
It's so hard to "read" emotions or intent in forums like this.
mikerich1972
Quote from: 77turbopinto on March 29, 2008, 11:42:03 PM
This is an interesting topic. The possible adverse effects should be considered by anyone thinking of doing this. Thank you for posting some of the issues you did have, and some of your concerns too.
I wonder what the gains would be if the crankcase were vented outside of the vacuum like I mentioned before (all else equal).
The PCV system is considered to be an emission control and the EPA might not be that happy, at least not for street use.
I can tell you that the EFI 2.3T has a "Metered Air" system that is designed to work with a PCV and 'vented' crankcase. The vent is after the VAM so all the air in the engine is metered, so IF this were to be done it would not have an effect on the METERING of the air (mixture). One more thing to think about with this set-up: the location of the "vent", its between the VAM and the turbo; in a vacuum area. Other possible effects, good or bad, are still a '?'.
I would think that it would change the mixture for a carb.ed engine (fixed mixture). Yes, some, if not all Pintos have the vented oil cap have a tube to the air can, but it is located before the air fliter (restriction).
Cars with "Speed Density" or "MAP" sensors might not deal well with the change (I don't know).
Great points!!
I have modified a 2006 Chrysler minivan, and a 2005 Ford F-150. Both operated just fine with this done. The only complaint from the owner was about the "whistle". This was only noticable upon shutdown, but they wanted them both reversed anyway. These, and the vehicles mentioned in the article are the only experience I have with fully "comptuered" cars.
By the way, both of these vehicles saw a solid 1.5 miles per gallon increase for the short time I had the mods on them.
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
Quote from: 77turbopinto on March 27, 2008, 07:37:56 PM
I fully understand the word "vacuum".
The PCV system does put a vacuum to the crankcase, but with the crankcase that is vented, outside air is pulled into the crankcase: 'a vacuum leak'. If it were not putting a vacuum to the crankcase, air would not be pulled in through the vent.
By sealing the vent ('leak') you will limit the amount of hot gas that will be pulled out of the crankcase and into the engine, and in turn your intake air temp will go down. That will go along with any benefit that a negative pressure in the crankcase might give you.
A N/A (regular) car will draw more vacuum at idle or 'decel' than with an open throttle (like highway driving).
Of course ANY modification to the intake air might have other effects too, and those must be considered before-hand (tune, choke, federal laws...).
BTW: What I don't understand is why you don't want to just post all of your information here, or post a link, and make it "public."
Sorry bill, no direspect intended. I never know what level of knowledge is out there. You obviously DO understand what's going on!!
2003 Ford Motorhome
2018 Ford Focus
Quote from: earthquake on March 30, 2008, 09:41:16 AM
3 letters (EPA) :(
you maybe partially corect but i think that if 'big business' could do something so simple & inexpensive & effective why wouldn't they do it?  in my opinion, because it has been researched and set aside as not being feasible.
there have been throught the years, no lack of 'devices' along the same lines as this idea. an xample is the '300' or '100' MPG carburetor.
the epa & the auto manufacturers are not ignorant of ideas & 'out of the box' thinking when it comes to designing vehicles & the power plants that allow them to move.  yes, they do have a vested interest in selling cars/trucks and the parts to service them.  so does 'big oil' have a vested interest in perpetuating the aut industry as a huge consumer of oil. but in the political climate that is prevalent in this day & age a simple procedure or device such as this would have been implemented already.
100+mpg+carburetor
cut & paste this into google:
there are listed page after page of 'ideas' that will change the future of the automotive world for the better.
all that being said;  i have never tried any of this and i'm not saying that any of these ideas don't or do work. i am saying that with the united states full of the best engineers & researcher as well as a few govt. aencies devoted to the science and application of such ideas, i would think that an idea such as this would be a bit more 'mainstream' than showing up on a forum in an enthusiasts web site
earthquake
Quote from: srt on March 30, 2008, 02:55:21 AM
Might I ask why, if this is so cost & fuel efficient; not to mention (your implication, not mine) that it is common sense;  do not all auto manufacturers utilize it?
3 letters (EPA) :(
Quote from: mikerich1972 on March 29, 2008, 06:02:46 PM
......The nasty vapors are still drawn off and burned in the engine, so the emissions have not increased, and the EPA will be happy......
........I want to point out that the on-board computer in newer vehicles doesn't care about this modification! (The computer does not control or monitor the PCV in any way.).......
