cam pulley
Date: 05/30/2018 04:56 pm
Date: 10/31/2018 12:04 pm
Date: 11/23/2017 05:44 pm
Date: 04/24/2018 11:45 am
Date: 12/04/2018 07:40 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 08/17/2022 06:27 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
  • Online today: 1,185
  • Guests: 643
  • Total: 643
1976 Wagon with 308.000 miles!
Started by mikerich1972, March 24, 2008, 07:47:13 PM
mikerich1972
Now for the possible down-sides of doing this, and what I have observed.
  Will the oil retain more contaminants?.    I believe it will. Since the PCV is not as effectively removing the volatile contaminants from the crankcase, the oil will become the reservoir for these contaminants. This means, simply, change your oil at the recommended intervals!
  • The water vapor cannot as easily be purged from the engine.     When we look at how this water vapor enters the engine, it becomes very clear. It comes into the crankcase via the normal PCV system. Since we no longer have an open air inlet for this moisture to enter, I believe the water vapor that is now in your engine will be pulled out, albeit more slowly. However, the influx of water vapor is now nearly eliminated.
  • What about a negative affect on the gaskets and oil seals?    Again, I have not seen any oil leaking from the Pinto engine. And I do mean that there is virtually ZERO leakage from the main seals (or anywhere, for that matter) on this engine. (I truly hate a leaky car.)
  • Will I see increased oil consumption?     This old 291,000 mile Pinto engine has always used some oil, and I've driven the car daily since May, 1988. I can count on about 1,600 miles to the quart of oil consumed. This has not changed.
  • Rough idle?   No, I think it actually idles a bit smoother.
  • Why hasn't Detroit done this years ago?     The auto manufacturers are after one thing, your money. They simply don't care how much that new car costs to operate.
I am only trying to pass along information that I believe is important enough to share with everybody who will listen. Again, I am not making a dime on this, nor do I expect to, ever. Please give this some thought, as a lot of fuel is potentially at stake. Consider at least trying it for a while.  My satisfaction will come in the knowledge that I may have had a small part in reducing emissions and our country's dependence on imported oil. Any oil, for that matter!
UPDATED INFORMATION:
In reference to the previously mentioned negative affect on the engine's oil seals... I have some new data to share.
Problem:  Rear oil seal leakage: I modified the PCV system on my Chevrolet S-10 class-C motorhome. The engine is a 2.8 liter V-6. In late July, 2006 we were leaving town for a long weekend of camping. I started to smell oil burning; never a good thing to experience! After finding a suitable wide spot on the highway, I noticed that the rear main oil seal was leaking quite well. Actually, it was nearly a steady stream of oil at idle. Now, please understand that we had driven this vehicle on a 7,200 mile tip across the US in September and October of 2004, with not a bit of mechanical trouble. This just had to be caused by the mods I had made to the PCV system. The process of replacing the original PCV system was done very quickly (it took about 10 minutes, tops!) and I proved to myself that it had indeed been the cause.
What had happened is this: the engine's crankcase had a negative pressure that was actually opening the rear main oil seal. This seal is supposed to be held closed by the pressure of the oil pushing against it from the inside. But a deep enough vacuum pulled in air past the seal, allowing oil to be pushed out.
The oil leak immediately stopped, and hasn't dripped in the 240 miles since.
In fact, my 1992 Ford Ranger pickup and my brother's Ford half-ton PU both have a distinctive "whistle" after we shut them off from an idle. This indicates a deep vacuum within the crankcase, with absolutely no adverse affects! In fact, my brother's Ford pickup idles at about -20" HG., and this engine has no problem with oil leaks.  So, some engine's oil seals just seem to be more sensitive to a vacuum.
I never did check the vacuum in the crankcase on the Chevy's engine; maybe I should have. But I tend to believe it has more to do with the design of the oil seals than anything. I've chosen to run this engine without the PCV modifications due to the limited in-town or moderate loading of the engine. However, I have come up with a remedy, should this be a problem to others.
Cure:  I have researched the availability of an adjustable vacuum relief valve. They are a simple device that will prevent the crankcase vacuum from reaching below the valve's setting. A ¼" NPT model is in stock locally for about $10 (Grainger's). This will need to be installed in line between the valve cover and (preferably) the air box or air cleaner. If this valve setting is adjusted correctly, probably 6" to 8" HG, then it will open as needed at idle and downhill, etc. With the tubing run into the clean air stream, the engine will not have a new influx of dirt.
How are my other cars doing?  The old Pinto is still running flawlessly at 298,750 miles (as of 11/18/06). It's still averaging right at 26 MPG in town!! This is not running on the highways; it is 99.99% stop-and-go city driving. The Ranger pickups are still running fine. We are still seeing a similar MPG stated previously.
What about the highway mileage? I really haven't seen any increase in MPG over the 7,700 miles since I first modified the Pinto. But, there hasn't been any DECREASE in MPG either. Our Ranger pickup; pretty much the same highway mileage, also.
Please feel free to copy and forward this to as many people as you wish!!!
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
Modify Your Engine's PCV System to Gain up to 17% MPG
The idea is to reduce our country's dependence on foreign oil and save you money. I do not want your money in any way.
Now that you understand where I'm coming from, here's the deal... Would you spend about 20 minutes and under $10 to modify your vehicle's engine, and gain 5 – 17% increase in miles per gallon? There is nothing to wear out, replace, clean, renew, or change ever again. This is a one-time modification that will last for many years.
Still interested? Read on.
In the very competitive game of bracket drag racing, the engines are covered by many extremely restrictive rules. Any small horsepower gain that can be found within these rules is a huge advantage. Reduce the internal "drag", or rotational resistance, and you have a more efficient, more powerful engine. Some "old" drag racers have known this for a long time. They have been connecting vacuum pumps to their engines for an overall gain of nearly 10 horsepower. Small gain, yes; but an advantage of about 5%!!
In this application, we will put the engine's own Positive Crankcase Ventilation (PCV) system to work for us. We use the PCV system to reduce the pressure inside the engine's crankcase, thereby reducing the quantity of air that must be displaced by each piston as it travels downward. With the reduced air resistance within the engine, it naturally rotates easier.
So, how do we do this?     What you need to understand is how the PCV system works. It pulls filtered air into the engine block. This purged air is then pulled into the intake manifold, where it is burned in the engine. Simple, all we have to do is cap, or plug this airflow INTO the engine's crankcase. This is usually done with a small (1/2") tube that leads from the airbox (or downstream of the air filter) to the engine. It is generally connected to the engine on one of the valve covers. By capping this tube, be certain that you are preventing air infiltration two ways: into the tube leading to your valve cover; and into the air intake, or airbox. Because we don't live in a perfect world, make sure that all the tubing connections are tight. Let me go beyond that, they need to be VACUUM TIGHT. This may not be an easy task on older vehicles, as I will explain later, but well worth it.
We are now causing the crankcase air pressure to be changed from near atmospheric to at least -4" mercury (HG). The manifold vacuum usually runs at about -24" HG at idle. This is transferred to the crankcase by blocking the air flow. (The nasty vapors are still drawn off and burned in the engine, so the emissions have not increased, and the EPA will be happy.)
Does this REALLY work?    The first engine I modified is my 1976 Pinto with a 2.3 liter 4 cylinder. (Yes, they still DO exist!) This engine now has 291,000 miles, and runs as well as anything else on the road. I probably have driven about 1,200 miles since I capped the PCV, and I have seen no increased oil consumption, or other adverse effects. This is a true high-mileage engine with plenty of wear and blow-by. In my mind, if any engine is going to bite the dust through this, here is a classic case. (I wasn't especially worried because I have a rebuilt engine awaiting the day this old one dies). The around-town MPG increased from 21 - 23 up to 25 - 27, depending on the temperature. (Since this is a carbureted engine, the choke does play a role in economy). After the first tank of fuel, the MPG dropped back down to the normal (22 MPG) range. Slightly discouraged, I took a closer look at the whole PCV system. What I found was a bit of a shock. The oil filler cap on the old Ford was set up for a hose to the air filter. I had simply blocked this at the cap. After a while, the oil that had soaked into the seam of the two-piece metal cap had been pulled out by the vacuum, creating a new air leak. I eventually replaced the cap with a non-breathable one from another application. This, along with being extremely aware that vacuum leaks are nasty little annoyances and, careful attention to the gasket on the cap, cured the leak. The crankcase vacuum now runs at -4 to-5" HG at idle. The in-town fuel economy again changed for the better! Back up to, per the latest tank of fuel, 26.49 MPG. Not bad for November...
I did this on my dad's 2003 Ford Ranger. This is a two-wheel drive, 4 cylinder with a manual transmission.  He was getting similar MPG's around town, averaging 22 to 23. In the latest report, he is still getting 26 to 27 MPG in town.
I want to point out that the on-board computer in newer vehicles doesn't care about this modification! (The computer does not control or monitor the PCV in any way.)
In both cases, this is an increase of 17%
I honestly do not have enough data on highway mileage to conclude anything, but I suspect the increases would be slightly lower. More in the range of 5 – 10%, due to the decreased manifold vacuum at highway speeds.
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
Hey guys. Look into JEG'S or any other racing equipment outlet and you will fine VACUUM pumps designed for this purpose. And that is to keep a vacuum in the crankcase!! Read up on it too.. They claim to gain up to 14 or so horses!
2003 Ford Motorhome
2018 Ford Focus
At 308,000 miles and 42 years my bet is 99.9% their hard. I agree if done yourself it is a good investment. If your paying someone then just get the whole had redone. But, this doesn't account for ring/bore wear.  So, I'd say either do the seals yourself, or just keep driving it and add oil as needed.  BTW, my 150,000 mile turbo motor still has a nice crosshatch on the cylinder walls. Ford did something right.
If you do it yourself I recommend the using thin rope in the cylinder to hold the valve in place while the spring is compressed. Happy motoring and may you get 308,000+ more!
That's great , if it's using oil you might try changing the valve stem seals , you do not have to pull the head and worth the effort, had them get hard as a rock on a few pintos and rangers with the 2.3 , easy way to check them is to pull the valve cover and use a ice pick and stick the side of the seal through the valve springs , if they are soft they are good , if they crack and crumble they are bad , hope ''this tip helps everyone ,
That wagon of yours is nothing short of amazing.  I hope mine proves to be just as reliable.
Dwayne :)
mikerich1972
Well, more news on the "old" wagon.
It now has 360,900 miles on the original block. Uses oil, but the oil pressure is still over 55 PSI and the last time I ran a compression check all the cylinders were within reasonable range. Still a great daily driver, and it gets a lot of attention!!
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
It's now at 343,600 miles officially!!
Still runs as well, if not better, than new.
2003 Ford Motorhome
2018 Ford Focus
chrisf1219
i hit 80000 orignal miles so i guess im good for aleast 200000 more!!!!!  chris
Pretty darn good, it must of been well taken cared for..
mikerich1972
Okay.. we now have 343,600 miles on the old Pinto. However, I noticed on Monday that it's got a cracked exhaust manifold. Thanks to another member here (thanks, Derek!!!), I'll be getting another one soon, along with my original one braised. I'll have it back on the road by Friday.
Not bad for a really high mileage engine!!!
2003 Ford Motorhome
2018 Ford Focus
Quote from: dga57 on November 07, 2010, 09:50:53 PM
Sounds like your Ford might have a little Timex blood in it... takes a lickin' and keeps on tickin'!
Or energizer batteries... They keep going, & going, & going......  ;D
mikerich1972
Still running great at 326,650 miles!!!
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
FYI: The old Ponto just turned over 326,000 miles this weekend!!  Still runs great on the original block.
2003 Ford Motorhome
2018 Ford Focus
Quote from: mikerich1972 on March 22, 2010, 08:51:54 PM
When I told him of the high original miles and that it's driven daily, he just about fainted.
I get that too... but not from a Pinto. I have a chev lumina mini-van with 392,000 miles confirmed on the original drive train, 3 previous owners are known and motor still runs strong enough to have towed one of my cars home last year on a dolly, 200+ mile trip. My kid is the current driver and it still looks ok. funny thing is... it's the daily driver that has needed the least amout of work/repairs in the last year or more...
keep them wheels turning...
mikerich1972
 I got stopped today by a guy in a 1951 Chevy panel. He had followed me for about 5 blocks, apparently admiring my Pinto! He asked the usual questions about the paint, and its age. When I told him of the high original miles and that it's driven daily, he just about fainted.
Funny thing, though. For a guy in his late forties, he had no idea what it was until he read the emblems on the car!! I guess maybe more of those Chevy guys still need to be educated.  :welcome:
2003 Ford Motorhome
2018 Ford Focus
mikerich1972
The latest on the high-mile Wagon......
I am now putting the original emblems back on the hood, tailgate, and dash. I removed them years ago, to simply get a few smiles and curious looks from others (I replaced the tailgate and dashboard emblems with FIREBIRD). I think it's time to get it back into great original condition for the car show season. We are constantly being asked about this car, so why not let others enjoy it too?   :smile:
We have a local show called "Cool Desert Nights" that we usually attend and show one of our Pontiacs. This is no small affair... it averages over 500 entries! Last year, we were reminded that we could cruise anything we want, as long as we have a vehicle registered for the show! This year, the Pinto will definitely do the Friday night cruising!!!
The car now has slightly over 321,000 (actually 321,081) ORIGINAL miles, and I see no mechanical problems in the engine yet!   :surprised:    No worries, though. I rebuilt another 2.3 and have it waiting for the inevitable engine swap, when that day finally arrives!
2003 Ford Motorhome
2018 Ford Focus
Thanks Mike... I am hoping to have some better luck with her after it warms up & I get her fixed.
mikerich1972
Wow, R4pinto !!!!
Sorry to hear about the bad luck with yours..... I have driven mine almost daily for, well it will be 22 years in May! I bought the car with about 97,000 on the odometer, so I've put on most of the miles now.
2003 Ford Motorhome
2018 Ford Focus
Nice to see someone having good luck with their Pinto. Since 2006 I have put maybe 50 miles on mine, and everything has gone wrong on it. If you combine your & my Pinto we got a normal car lol
Impressive to see it still going, Mike!
I'm going to trade mine in at 100,000 miles  :lol: not.
Are you using the dielectric grease on the plug boots when you mess with them? I don't know if you can tell if you're losing juice there. Just a thought...
Also, are they fouling? or are the insulators crumbling? How many miles do you get out of your plugs? I've been through 2 sets in 17k miles. They're usually black/sooty ( my car runs a bit rich) The first set the insulators on 2 broke when I took them out. I'm using Splitfire plugs right now, they seem to be holding up ok.
Chuck :afro:
mikerich1972
Not much chance of the problem being a plug wire. I often check the ignition system with my indcutive timing light, which also checks the wires the way I kook it up.
Thanks, though!
2003 Ford Motorhome
2018 Ford Focus
I'm glad she's still running strong for you Mike! Could it be something besides the spark plug though? Like a spark plug wire or bad cylinder?
Looks great!! Looks like Joe's in Morgan Hills car!!!
