Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 03/30/2021 12:29 pm
Date: 07/20/2018 03:00 pm
Date: 03/25/2019 09:02 pm
Date: 10/02/2017 02:16 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 07/20/2017 01:23 am
Date: 08/05/2018 01:58 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
  • Online today: 427
  • Guests: 410
  • Total: 410
what are the 71 72 gear ratios
Started by skippy, March 02, 2008, 06:14:27 PM
Quote from: Pintony on March 03, 2008, 07:21:42 AM
Hello Srt,
To get a 3.82 ratio you would have to have a ring-gear with 42 teeth W/ 11 pinion To get the 3.73 you need a 41 ring and a 11 pinion. so they are really close.
You are most likely correct depending on your source of information.
that was 30 + years ago.  you're right though, real close and probably would never feel the difference.  my girlfriend at the time had a '73 with the automatic & 3:18 that i swapped with a 3:40.  now that made a heck of a good driver
Blacksheep22
Just for info my 73 Wagon came stock with 2.0 auto and a 3.45 rear.
71 Pinto Mini-Stock 1994 Track Champion
72 Pinto all original 63000
73 Pinto Wagon 2.0  4 Speed 8inch
Quote from: srt on March 03, 2008, 03:20:25 AM
Hey   Tony, there  was a 3:73 available too but I'm not too sure of the year. Do you know?   I thought it was the ratio that was available in the 1600
Hello Srt,
Hello Skippy,
The 1971-72 Pinto axle codes are on the drivers door jamb near the striker post.
The  codes are as follows.
G= 3.55 "Most common in 4speed cars."
7= 3.18 "Most common in automatic cars."
H=3.82 Only found in the 1.6L cars
Also 1.6L Pintos were never offered with the Auto transmission.
skippy
hi im looking at buying a pinto and the person say it seams to run out of gear. the car was a 4 speed and now its a auto. so what could the gears is the rear be from the factory. he says as far as he knows they havent been changed.
