Date: 12/10/2017 01:14 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
parts needed
Date: 02/20/2017 07:58 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 08/08/2017 01:44 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
  • Online today: 1,459
  • Users: 1
  • Guests: 129
  • Total: 130
  • Wittsend
Looking to pull out some stops on my Pinto - may need some assistance
Started by cdg, March 02, 2008, 12:04:31 AM
Quote from: cdg on March 02, 2008, 02:37:16 AM
Dave, what year/engine was your Pinto?  The 2300 didn't get EGR until '79, at least on models sold outside of California...  I just want to gauge how similar our two vehicles are, since the '79 and '80 models saw a lot of substantial changes in the emissions gear on the Pinto.
All my '77s and '78s have had EGR valves.
I have a 78 with a 2300. I have a Holly/Weber 5200 on it with electric choke and a carb base with EGR port on the driver's side and the exhaust manifold with the hole for the EGR valve return tube. I also still have the original tube the EGR valve had.
Emissions things have been hard to address on my Pinto as it isn't the same as ANY other Pinto I have ever seen or heard about. It seems like it's a mix between a 77 and a 78, but nothing is consistent enough to really set on any decision. My pillar sticker says June 12th of 1978 though.
cdg
I was experiencing a similar problem at the end of last year, which was due to the valve being cracked by one of the bolt holes. I bypassed my EGR connection by replacing the vacuum hose with a longer one that ran straight to the carb/carb base (I can't recall).
I removed the EGR valve, purchased a new gasket for $3.99, cut a section of 1/4" thick aluminum to the same size of the EGR valve mount and bolted it on with the gasket between the carb base and the block-off plate.
I then removed the tube leading back to the exhaust manifold, which was rusted to the manifold, and plugged it up with a brass plug from a local surplus supplier which cold me $9.99.
After all of that I started it and let it warm all the way up, dropped the curb idle just a tad and called it a day.
Total cost - $14.82 & 1 1/2 hours of labor
Still cheaper than the EGR valve I could have replaced the original with for $94.99, and no more having to worry about it down the road!
So far I haven't had any problems with the car what-so-ever, unlike it was before where it would experience problems every couple of weeks and I had terrible gas mileage. I however do not know what I am getting now, but I can definitely tell it is better than before.
cdg
OK, so I suspected for a while that my '80 2.3/C4 Pinto had a bad or clogged EGR valve (it had some hesitation off of idle, and would occasionally idle like crap until it was run fairly hard.  I pulled the EGR valve today and I can safely say it was probably one of the worst carbon-clogged nightmares I've ever seen.
Another symptom that I've noticed is this car is getting about 10 or 12 mpg.  I know these aren't the latest in fuel injection technology, but I was hoping for 15 or 20 around town, maybe 22 or 25 on the freeway.  Is there a problem here, or am I just expecting too much?
I have no interest in preserving the 1970s smog gear on this car.  But I'm not really familiar with the Pinto in and out.  It is 7 years older than I am, and I can honestly say that growing up in Pennsylvania, I don't think I've ever worked on one before owning this car.
So I want to go ahead and block off the EGR valve.  I'm thinking that the valve can be removed, a plate welded across the carburetor spacer where it once went, the tube unbolted from the exhaust manifold, and plugged with a bolt (and welded if necessary).
But where I'm not certain is what removing the valve will imply in the vacuum system of this car, which is already made of a lot of suspect looking old rubber hoses.  Can I just plug up the old vacuum hose and call it a day, or am I missing something in this equation?
The valve is temporarily disabled (I wanted to move it from the spot where I was working on it, and I was curious to see what would happen).  I disabled it via some gasket making material, some tin can material, and the old valve bolted over top of the can to make a nicely sealed off EGR block.  I plugged off the vacuum line to the valve via an eyglass repair screwdriver and some electrical tape until I can get the vacuum block I need.
The car starts and runs, but it seems to idle faster than I remember it idling before (it is not on it's fast idle circuit, however).  I'm not going to put too much stock in the tenth mile I drove it with a relatively poor EGR block, but I'm curious if anybody has any input here.  I just wonder if the valve was a long time in the failing, and the last guy who worked on it down the line didn't just turn the idle up a little to try and compensate the for the leaky/sticky old valve.
Lastly, I read the Chilton manual, and one of the systems the vacuum to the EGR valve is related to is some sort of cold start timing retard feature Ford put into the post '79 cars to aid in cold starting.  I can't tell for sure if I should block the EGR hose, or if I should leave it to leak vacuum.
