1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 10/03/2018 10:46 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Bumpers
Date: 07/06/2018 04:47 pm
Date: 02/18/2017 04:41 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 02/22/2017 01:58 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
  • Online today: 585
  • Guests: 587
  • Total: 587
2.3 dipstick and fuel pump hole
Started by volksnut, February 12, 2008, 09:43:27 PM
volksnut
I drilled for the dipstick today, a little measuring and it was no problem missing the oil pickup tube...now I just need to find a good used dip stick tube...
map351
Drill a hole for the dip stick & put a elect fuel pump on it..
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
volksnut
late model 1987 block, has rear sump and dipstick, on closer inspection with oil pan off, there's no plug to remove for front sump dipstick, it has to be drilled, and will it miss the oil pump?   Also no fuel pump hole, has the provision for one with 2 threaded holes but block is cast over, looking inside at the timing/fuel pump shaft it has the provision for the pump arm to ride on....has anyone cut out the hole for the pump through the block?  1 step forward and 2 steps back :look:
