73 Runabout
Date: 11/20/2017 03:19 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 12/10/2017 01:14 pm
Mirror
Date: 04/15/2020 01:42 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 10/10/2019 10:02 pm
Crane Cam
Date: 02/26/2018 07:50 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
  • Online today: 1,459
  • Guests: 138
  • Total: 138
getting trans to fit late 2.3
Started by volksnut, February 11, 2008, 05:37:05 PM
I have cut a few to make them fit for Ford Rangers but I can't say on your application... just measure.
lay a ruler across the bell housing and measure to the tip of the input shaft to the flat ruler on both trans....you'll see the difference quick.
Best of Luck
FrankBoss
volksnut
can it be cut, will it throw anything else out of wack...it does have the same gears though right
the 6 tranny input shaft is longer....Sorry
FrankBoss
volksnut
well the saga continues, I'm installing a late 1987 2.3 Mustang motor in my daughters 74 Mustang II,  the trans is a RAD 4 speed from the 74 Mustang II, but it was formally a V6 car...on installing trans the output shaft bottoms out on crank before trans seats on bellhousing (3/4")...I do have the correct Mustang II bellhousing for the car....does the V6 RAD 4 speed trans have a longer shaft or is the later 2.3 have a shallower pilot bearing hole?  Anyone run into this before?  Could I just cut off 3/4" of the output shaft?
